mousho Posted February 8, 2022 Share Posted February 8, 2022 hi friends. i need help with dcl radio button what i need to change that the last radio button that i checked remain selected if i load the lisp again it alwayes check the "HOOPC" radio button DCL: :boxed_radio_row { //*define radio row label = "סוג חישוק" ; //*give it a label : radio_button { //*define radion button key = "HOOPC" ; //*give it a name label = "חישוק סגור" ; //*give it a label } //*end definition : radio_button { //*define radio button key = "HOOPO" ; //*give it a name label = "חישוק פתוח" ; //*give it a label } //*end definition : radio_button { //*define radio button key = "HOOPP" ; //*give it a name label = "חישוק לפיתול" ; //*give it a label } //*end definition } //*end radio row LISP (if (= HOOPC-value nil) (setq HOOPC-value "1")) (if (= HOOP nil) (setq HOOP "CLOSE")) (set_tile "HOOPC" HOOPC-value) (action_tile "HOOPC" "(setq HOOP \"CLOSE\")") (action_tile "HOOPO" "(setq HOOP \"OPEN\")") (action_tile "HOOPP" "(setq HOOP \"PITOL\")") Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 8, 2022 Share Posted February 8, 2022 Example: Add the following codes in okay button and keep the variable 'vars' unlocalized (setq vars (mapcar 'get_tile '("HOOPC" "HOOPO" "HOOPP"))) Then add the following at the top to reset the values back as they were when the user press okay button. (mapcar 'set_tile '("HOOPC" "HOOPO" "HOOPP") vars) Quote Link to comment Share on other sites More sharing options...
mousho Posted February 9, 2022 Author Share Posted February 9, 2022 12 hours ago, Tharwat said: Example: Add the following codes in okay button and keep the variable 'vars' unlocalized (setq vars (mapcar 'get_tile '("HOOPC" "HOOPO" "HOOPP"))) Then add the following at the top to reset the values back as they were when the user press okay button. (mapcar 'set_tile '("HOOPC" "HOOPO" "HOOPP") vars) I am using old lisp that i want to modify when i add the codes in the okay button i get error (progn (defun 2B_BEAMC (/ action reslist dcl_id BASE PP2 PP3 PP4 PP5 PP6 PP7 PP8 PP9 PP10 PP11) (setq action 6 reslist (list (cons "BASE" nil) (cons "B_DCL" (if (= B_DCL nil) 30 B_DCL)) (cons "H_DCL" (if (= H_DCL nil) 60 H_DCL)) );list );setq (setq dcl_id (load_dialog "BEAM V2022.dcl")) (while (>= action 2) (if (null (new_dialog "BEAMC" dcl_id)) (exit) );if (if (setq BASE (cdr (assoc "BASE" reslist))) (set_tile "BASE" (PointToString BASE))) (if (setq B_DCL (cdr (assoc "B_DCL" reslist))) (set_tile "B_DCL" (rtos B_DCL 2))) (if (setq H_DCL (cdr (assoc "H_DCL" reslist))) (set_tile "H_DCL" (rtos H_DCL 2))) (defun CheckValues () (if (and BASE B_DCL H_DCL ) (mode_tile "accept" 0) (mode_tile "accept" 1) );if );defun (CheckValues) (action_tile "BASE" (strcat "(setq BASE (string_to_number (get_tile $key))" " reslist (subst" " (cons \"BASE\" BASE)" " (assoc \"BASE\" reslist)" " reslist" " )" ")" "(CheckValues)" );strcat );action_tile (action_tile "B_DCL" (strcat "(if (setq B_DCL (atof (get_tile $key))) (setvar \"userr4\" B_DCL))" "(setq reslist (subst" " (cons \"B_DCL\" B_DCL)" " (assoc \"B_DCL\" reslist)" " reslist" " )" ")" "(CheckValues)" );strcat );action_tile (action_tile "H_DCL" (strcat "(if (setq H_DCL (atof (get_tile $key))) (setvar \"userr4\" H_DCL))" "(setq reslist (subst" " (cons \"H_DCL\" H_DCL)" " (assoc \"H_DCL\" reslist)" " reslist" " )" ")" "(CheckValues)" );strcat );action_tile (if (= HOOPC-value nil) (setq HOOPC-value "1")) (if (= HOOP nil) (setq HOOP "CLOSE")) (set_tile "HOOPC" HOOPC-value) (action_tile "HOOPC" "(setq HOOP \"CLOSE\")") (action_tile "HOOPO" "(setq HOOP \"OPEN\")") (action_tile "HOOPP" "(setq HOOP \"PITOL\")") (action_tile "cancel" "(done_dialog 0)") (action_tile "accept" "(done_dialog 1)") (action_tile "BASEbtn" "(done_dialog 2)") (action_tile "B_DCLbtn" "(done_dialog 3)") (action_tile "H_DCLbtn" "(done_dialog 4)") (setq action (start_dialog)) (cond ( (= action 2) (if (setq PP2 (getpoint "\nBASE Point: ")) (setq reslist (subst (cons "BASE" PP2) (assoc "BASE" reslist) reslist );subst );setq );if ); ( (= action 3) (if (setq PP3 (ugetd "\nWidth Of Beam (cm) ")) (setq reslist (subst (cons "B_DCL" PP3) (assoc "B_DCL" reslist) reslist );subst );setq );if ); ( (= action 4) (if (setq PP4 (ugetd "\nHeight of Beam (cm) ")) (setq reslist (subst (cons "H_DCL" PP4) (assoc "H_DCL" reslist) reslist );subst );setq );if ); ( (= action 0) (setq reslist nil)) );cond );while (unload_dialog dcl_id) (if (= action 1) (setq reslist reslist) (exit)) ; reslist );defun ; ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 9, 2022 Share Posted February 9, 2022 You need to put the codes in the accept action although that I can't see them in the routine posted !. 1 Quote Link to comment Share on other sites More sharing options...
mousho Posted February 9, 2022 Author Share Posted February 9, 2022 1 hour ago, Tharwat said: You need to put the codes in the accept action although that I can't see them in the routine posted !. Thanks . Work like a magic Quote Link to comment Share on other sites More sharing options...
