DCL Radio Button
mousho
hi friends.
i need help with dcl radio button
what i need to change that the last radio button that i checked remain selected if i load the lisp again
it alwayes check the "HOOPC" radio button
DCL:
       :boxed_radio_row {					//*define radio row
       label = "סוג חישוק" ;				//*give it a label
        : radio_button {					//*define radion button
     	  key = "HOOPC" ;					//*give it a name
     	  label = "חישוק סגור" ;			//*give it a label
        }									//*end definition
     	: radio_button {					//*define radio button
     	  key = "HOOPO" ;					//*give it a name
     	  label = "חישוק פתוח" ;			//*give it a label
     	}									//*end definition
     	  key = "HOOPP" ;					//*give it a name
     	  label = "חישוק לפיתול" ;			//*give it a label
     	  }									//*end definition
		}									//*end radio row
LISP
	(if (= HOOPC-value nil)	(setq HOOPC-value "1"))
	(if (= HOOP nil)		(setq HOOP "CLOSE"))
	(set_tile "HOOPC" HOOPC-value)
	(action_tile "HOOPC" "(setq HOOP \"CLOSE\")")
	(action_tile "HOOPO" "(setq HOOP \"OPEN\")")
	(action_tile "HOOPP" "(setq HOOP \"PITOL\")")
Example:
Add the following codes in okay button and keep the variable 'vars' unlocalized
(setq vars (mapcar 'get_tile '("HOOPC" "HOOPO" "HOOPP")))
Then add the following at the top to reset the values back as they were when the user press okay button.
(mapcar 'set_tile '("HOOPC" "HOOPO" "HOOPP") vars)
12 hours ago, Tharwat said:
Example:
I am using old lisp that i want to modify
when i add the codes in the okay button i get error
(defun 2B_BEAMC (/ action reslist dcl_id BASE PP2 PP3 PP4 PP5 PP6 PP7 PP8 PP9 PP10 PP11)
	(setq action 6
        reslist (list
					(cons "BASE" nil)
					(cons "B_DCL" 			(if (= B_DCL nil) 		30 B_DCL))
					(cons "H_DCL" 			(if (= H_DCL nil) 		60 H_DCL))
				);list
	);setq
	(setq dcl_id (load_dialog "BEAM V2022.dcl"))
	(while
		(>= action 2)
		(if
			(null (new_dialog "BEAMC" dcl_id))
			(exit)
		);if
	(if (setq BASE 				(cdr (assoc "BASE" reslist))) 				(set_tile "BASE" (PointToString BASE)))
	(if (setq B_DCL 			(cdr (assoc "B_DCL" reslist))) 				(set_tile "B_DCL" (rtos B_DCL 2)))
	(if (setq H_DCL 			(cdr (assoc "H_DCL" reslist))) 				(set_tile "H_DCL" (rtos H_DCL 2)))
    (defun CheckValues ()
      (if
        (and BASE B_DCL H_DCL )
        (mode_tile "accept" 0)
        (mode_tile "accept" 1)
      );if
    );defun
    (CheckValues)
(action_tile
      "BASE"
      (strcat
        "(setq BASE (string_to_number (get_tile $key))"
        "      reslist (subst"
        "                (cons \"BASE\" BASE)"
        "                (assoc \"BASE\" reslist)"
        "                reslist"
        "(CheckValues)"
      );strcat
    );action_tile
(action_tile
      "B_DCL"
      (strcat
        "(if (setq B_DCL (atof (get_tile $key))) (setvar \"userr4\" B_DCL))"
        "(setq reslist (subst"
        "                (cons \"B_DCL\" B_DCL)"
        "                (assoc \"B_DCL\" reslist)"
        "                reslist"
        "(CheckValues)"
      );strcat
    );action_tile
(action_tile
      "H_DCL"
      (strcat
        "(if (setq H_DCL (atof (get_tile $key))) (setvar \"userr4\" H_DCL))"
        "                (cons \"H_DCL\" H_DCL)"
        "                (assoc \"H_DCL\" reslist)"
        "                reslist"
        "(CheckValues)"
      );strcat
    );action_tile
	(action_tile "cancel"  "(done_dialog 0)")
	(action_tile "accept"  "(done_dialog 1)")
	(action_tile "BASEbtn" 			"(done_dialog 2)")
    (action_tile "B_DCLbtn" 		"(done_dialog 3)")
    (action_tile "H_DCLbtn" 		"(done_dialog 4)")
    (setq action (start_dialog))
    (cond
      ( (= action 2)
        (if
          (setq PP2 (getpoint "\nBASE Point: "))
          (setq reslist
            (subst
              (cons "BASE" PP2)
              reslist
            );subst
          );setq
        );if
      ( (= action 3)
        (if
          (setq PP3 (ugetd "\nWidth Of Beam (cm) "))
          (setq reslist
            (subst
              (cons "B_DCL" PP3)
              reslist
            );subst
          );setq
        );if
      ( (= action 4)
        (if
          (setq PP4 (ugetd "\nHeight of Beam (cm) "))
          (setq reslist
            (subst
              (cons "H_DCL" PP4)
              reslist
            );subst
          );setq
        );if
      ( (= action 0) (setq reslist nil))
    );cond
  );while
	(unload_dialog dcl_id)
	(if (= action 1) (setq reslist reslist) (exit))
;  reslist
);defun
1 hour ago, Tharwat said:
You need to put the codes in the accept action although that I can't see them in the routine posted !.
Thanks 🙏. Work like a magic
