muck Posted February 8, 2022 Share Posted February 8, 2022 Recently my AutoCAD LT 2014 takes a long time to check license. This started when the IT people did some updates. Is there any way to fix this? I am working with windows 10. Thanks you, Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 8, 2022 Share Posted February 8, 2022 I would start with the IT department and have them check what they have done. See if any of this helps. AutoCAD Products hang or crash during startup at checking or loading license | AutoCAD | Autodesk Knowledge Network 1 Quote Link to comment Share on other sites More sharing options...
muck Posted February 10, 2022 Author Share Posted February 10, 2022 IT said that my computer is getting old. That Is about all they said. I think IT's updates are really causing the problem. I know IT has upgraded Kaspersky Antivirus. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 10, 2022 Share Posted February 10, 2022 If you are correct, it would be easy to test your theory. Ask IT to temporarily disable Kaspersky Antivirus on your machine. Then start AutoCAD LT and load your largest drawing. How long does it take for AutoCAD LT to load? How long does it take to open your largest drawing? Then have IT enable Kaspersky Antivirus and retest. How long does it take AutoCAD LT to load and how long does it take to open the same drawing. What are your computer specs? 1 Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 11, 2022 Share Posted February 11, 2022 If the anti-virus is the issue, you probably can have IT whitelist all the *.dwg files. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 14, 2022 Share Posted February 14, 2022 The OP mentions nothing of drawing problems, just a long time to check the license. I posted the solutions, if your IT is unwilling to correct them, not much can be done. Quote Link to comment Share on other sites More sharing options...
