Is There a Lisp to make Ncopy Command use the current layer to bring the Copied objects to it automatically
Ahmed Khaled
Hi, I'm asking if there Is a Lisp to make Ncopy Command use the current layer to bring the Copied objects in to it automatically
Thanks in advance
COPYTOLAYER  Didn't realize n was for nested.
;Nested Copy to current Layer
(defun C:NCL (/ LastEnt SS en)
  (setq LastEnt (entlast))
  (C:ncopy)
  (setq SS (ssadd))
  (if (setq en (entnext LastEnt))
    (while en
      (ssadd en SS)
      (setq en (entnext en))
  (setvar 'cmdecho 0)
  (command "_.Chprop" SS "" "LA" (getvar 'clayer) "")
  (setvar 'cmdecho 1)
Edited by mhupp
  (C:ncopy)
  (setq SS (ssadd))
    (while en
      (ssadd en SS)
  (setvar 'cmdecho 0)
  (setvar 'cmdecho 1)
Thanks, but it return this error (; error: no function definition: C:NCOPY)
28 minutes ago, mhupp said:
Do you have the command loaded? its an express tool command on my end in BricsCAD.
Yes, Ncopy Command is Loaded and working
Would it need to be (command "ncopy") rather than (c:ncopy) if it is a normal command rather than LISP command?
For me after that it is saying "expects a point or settings"
NCOPY (Command) https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-12FCCFDF-9B3B-48D0-AC46-DF1D3519B0E5
Many of the original Bonus or Express Tools are simply AutoCAD commands now.
Those that are still lisp are only autoloaded with the command names. To use (c:xxxxx) you would have to preload the lisp before calling it.
This may help:
This may help:
I Appreciated it but that is not what I'm looking for, this command (NCopy) get the line on the same layer as xref not my drawing current layer
Try
(defun c:ncl ( / ent elist clayer)
	(setq ent (entlast))
  (command "_.ncopy" "\\" "" "_non" '(0 0) "_non" '(0 0))
	(while (/= (entlast) ent)
		(setq ent (entlast) elist (entget ent) elist (entget (entlast)) elist (subst (cons 8 (getvar 'clayer))(assoc 8 elist) elist))
		(entmod elist)
Edited by tombu
Updated to repeat until you press Esc key.
  • Thanks 1
39 minutes ago, tombu said:
Try
(defun c:ncl ( / elist)
	(setq elist (entget (entlast)) elist (subst (cons 8 (getvar 'clayer))(assoc 8 elist) elist))
	(entmod elist)
It Works Perfectly
Thank You Very Much
1 hour ago, tombu said:
Try
	(entmod elist)
Could you please make the command repeat itself until i press any key (like ESC) to exit it
I updated the code in my post above to repeat until you press the Esc key.
  • Agree 1
  • Thanks 1
Thanks. I couldn't have done it without you.
