Need help converting Mtext objects list (VLA-object?) to selection set
Hi.
I have a list of Mtext objects that I need to convert to a selection set,and this is the error that I'm getting:
; error : bad argument type <(#<VLA-OBJECT IAcadMText 00000000733971E0> #<VLA-OBJECT IAcadMText 0000000073397560> #<VLA-OBJECT IAcadMText 0000000073396760>)> ; expected SELECTIONSET at [sslength]
I've searched for answers and came with this 2 topics (topic1,topic2) but I could't make it work.
I've attached a sample drawing and the full lisp that I'm using.
in general,what Im trying to do is this:
1. select text objects
2. passing a list of those objects to a function that convert them to Mtext (I've found this lisp for that).
3. return a list of the Mtext objects to the main program.
(those 3 steps are successful).
4. convert the Mtext to blocks (the function converting the Mtext to block is good - see this topic.), but that function requiered selection set and I have a list...
Thanks,
Ari.
txtToBlk7.lsp txtToBlk7 test.dwg
Edited by aridzv
  • aridzv changed the title to Need help converting Mtext objects list (VLA-object?) to selection set
Can you post the code for steps 1-3?
and a sample drawing
Sorry its been a long night.
Edited by mhupp
Hi.
I've attached both the lisp and a sample drawing in my first comment - can't you see them?
if not I'll attach tem again.
about steps 1-3:
     (princ (strcat "\nSelect texts to be replaced with " tagname " Attributed Block:" ));; prompt the user to select the text objects
     (setq sel (ssget "_:L" '((0 . "TEXT")))) ;;creating a list named "sel" of those objects from a user selection.
     (setq sel1 (t2mtx sel));; call the lisp that convert text to Mtext and passing sel list to that lisp,and get the return list into sel1
(defun t2mtx (ss1 / lst usercmd) ;; the function that get the list sel,change the text to Mtext and return the list "sel1"
  ;;  CAB Text to Mtext conversion
  (defun T2M (code)
    ;; code =  dText Alignment code
    (cdr
      (assoc code
	      '(( 0 ;|acAlignmentLeft        |; . acAttachmentPointBottomLeft)
               ( 1 ;|acAlignmentCenter      |; . acAttachmentPointBottomCenter)
               ( 2 ;|acAlignmentRight       |; . acAttachmentPointBottomRight)
               ( 3 ;|acAlignmentAligned     |; . acAttachmentPointBottomLeft)
               ( 4 ;|acAlignmentMiddle      |; . acAttachmentPointMiddleCenter)
               ( 5 ;|acAlignmentFit         |; . acAttachmentPointBottomLeft)
               ( 6 ;|acAlignmentTopLeft     |; . acAttachmentPointTopLeft)
               ( 7 ;|acAlignmentTopCenter   |; . acAttachmentPointTopCenter)
               ( 8 ;|acAlignmentTopRight    |; . acAttachmentPointTopRight)
               ( 9 ;|acAlignmentMiddleLeft  |; . acAttachmentPointMiddleLeft)
               (10 ;|acAlignmentMiddleCenter|; . acAttachmentPointMiddleCenter)
               (11 ;|acAlignmentMiddleRight |; . acAttachmentPointMiddleRight)
               (12 ;|acAlignmentBottomLeft  |; . acAttachmentPointBottomLeft)
               (13 ;|acAlignmentBottomCenter|; . acAttachmentPointBottomCenter)
               (14 ;|acAlignmentBottomRight |; . acAttachmentPointBottomRight))
  (command "_Undo" "_end")
  (command "_Undo" "_begin")
  ;;(setq ss (ssget '((0 . "TEXT")))) ; get only plain text
  (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1))))
  (setq usercmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (mapcar
    '(lambda (x)
       (setq obj (vlax-ename->vla-object x)
             ali (vla-get-alignment obj)
             ipt (vlax-get obj 'InsertionPoint)
             apt (vlax-get obj 'Textalignmentpoint)
       (command "txt2mtxt" x "")
       (setq new (vlax-ename->vla-object(entlast)))
       (vla-put-AttachmentPoint new (eval (t2m ali)))
       (if (equal apt '(0.0 0.0 0.0))
         (vlax-put new 'InsertionPoint ipt)
         (vlax-put new 'InsertionPoint apt)
       (vla-put-width new 0.0)
       (setq lstnew (cons new lstnew))
    lst
  (setvar "CMDECHO" usercmd)
Edited by aridzv
no worries... 🙂
You commented out the part that converts the visual objects back to selection set again.
      (setq SS (ssadd))
      (foreach entityToAdd lstnew
      ;;(ssadd entityToAdd lstnew1)
        (ssAdd (vlax-vla-object->ename entityToAdd) SS)
      (princ SS)
      (princ "ggg")
      (repeat (setq int (sslength SS))
        (setq ent (ssname SS (setq int (1- int))))
        (setq ang (cdr (assoc 50 (entget ent))))        ;; get the Mtext Angle (in radians) and set it to the variable ang
        (setq ht (cdr (assoc 40 (entget ent))))         ;; get the Mtext hight (in radians) and set it to the variable ang
        (setq jus (cdr (assoc 72 (entget ent))))
Edited by mhupp
      (setq SS (ssadd))
@mhupp
Thanks!..
it has been a long night indeed... missed the double ssadd.
I've attached here the final lisp.
*EDIT:
Two clarifications regarding the previous lisp (txtToBlk7.lsp) comparing to the last one (txtToBlk8.lsp) :
1. in txtToBlk7 I left the line that get the Mtext justify with the DXF assoc code as 72,which will get a text object justify code and not a Mtext one.
    in txtToBlk8 I obviously changed it back to code 71: (setq jus (cdr (assoc 71 (entget ent))))
2. note that the final justify code is jus + 5. it seems that the first 5 codes are ignored by Mtext for some reason. I don't know why,but bottum line - that is how it's working...
txtToBlk8.lsp
Edited by aridzv
That's what I like about Visual Studio Code. you can compare two versions of lisp and see where the changes are very easily.
  • Thanks 1
