acad1985 Posted January 25, 2022 Share Posted January 25, 2022 Hello Everyone, I have a Drawing, in that i need to place the multiple dimensions from the Red Line (As Image). Is it possible to create multiple dimensions from the Selected or PLINE automatically by Lisp. Can anyone please help me out. Thanks in Advance. Quote Link to comment Share on other sites More sharing options...
exceed Posted January 26, 2022 Share Posted January 26, 2022 (edited) edited, google translater error Edited March 23, 2022 by exceed Quote Link to comment Share on other sites More sharing options...
acad1985 Posted January 26, 2022 Author Share Posted January 26, 2022 Hello Exceed, Thanks for your code. as you said this is working only with Y Axis line. when i try to angled line, the dimension created with the start point of the line. can able to create the dimension for angled line also? and also how to make dimension as attached image on Post#1.(Dimension Text should be outside either Left or Right) Thanks. Quote Link to comment Share on other sites More sharing options...
exceed Posted January 26, 2022 Share Posted January 26, 2022 you can approach like this get closest point from origin point to object then make dimension with that point. but in this case, have to think how to sort and offset them. and move dimension text is simple but delete inside line of dimension is automatically autocad do that in too short to place text case. anyother person can help you. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 27, 2022 Share Posted January 27, 2022 (edited) Somewhere have the sort v's point by making a list of ((offset pt )(offset pt ) ....) need also Lee's is point left or right of object so distance's are + -. Then use dims use correct points, may need to remove some of the dxf values in the dim so defaults are used. Will have a think. -12 pt1 -8 pt2 7 pt3 12 pt4 Edited January 27, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
acad1985 Posted January 28, 2022 Author Share Posted January 28, 2022 Hi Bigal, Could you please explain ,how to create points and create angular dimension. Thanks. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 28, 2022 Share Posted January 28, 2022 I had a quick look found my old program need to do some updating, I am testing with non perp lines. Maybe later today. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted January 31, 2022 Author Share Posted January 31, 2022 Okay Bigal, Thanks for your help. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 1, 2022 Share Posted February 1, 2022 (edited) This works as a left and right run twice, but supports any angle. REMOVED see later post Edited March 30, 2022 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 2, 2022 Author Share Posted February 2, 2022 Hi Bigal, Thank you so much, As you mentioned either one side, but it supports any angle. Thank you so much for this code. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 3, 2022 Share Posted February 3, 2022 (edited) I have fixed the dim text pt to be outside of the last offset. Picking twice can be removed by looking at left and right of pick point, but done simple for now. Edited February 3, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 3, 2022 Author Share Posted February 3, 2022 That was good Bigal, Can i get that updated one? I have few queries on this, in my drawing Reference line (Base line, Red color line, see Post#1) having Global width values, so when i select that line for place dimensions, it's not working. If i remove the global width from that line, then it's working. How to select global width line using this lisp. and can we place all dimensions Left or Right side (As Post#1), when i run this lisp twice, both set of dimensions will be placed on both side. Please give me any suggestion/solutions. Error on global width line, Can we align all the dimensions after the last line either left/right, is it possible? Thanks. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 4, 2022 Share Posted February 4, 2022 I updated the code above the text is placed at the 2nd pick point. Re left/right or all left or all right yes could be done. I will look into why pline with width does not work. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 7, 2022 Author Share Posted February 7, 2022 Thanks Bigal for your help again. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 9, 2022 Author Share Posted February 9, 2022 On 2/4/2022 at 11:05 AM, BIGAL said: I updated the code above the text is placed at the 2nd pick point. Re left/right or all left or all right yes could be done. I will look into why pline with width does not work. Hi Bigal, Sorry for disturb you again. Is there any update on this? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 9, 2022 Share Posted February 9, 2022 Ok simple fix in the code is a offset for selection I got lazy and did not remove the control line from a selection set so (setq pt1a (polar pt1 (angle pt1 pt2) 0.0001)) change the 0.0001 to a number just wider than your pline 1/2 width. I will see if can find time to change to remove the chosen object from selection. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 11, 2022 Author Share Posted February 11, 2022 Thanks Bigal, I have fixed the Pline width issue as per your guidance. could you please help me to place all dimensions Left or Right side (As Post#1), when i run this lisp twice, both set of dimensions will be placed on both side. Thanks again Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 11, 2022 Share Posted February 11, 2022 Will see if have time, will fix pline width also. Quote Link to comment Share on other sites More sharing options...
acad1985 Posted February 12, 2022 Author Share Posted February 12, 2022 Okay Bigal, Thank you so much. Quote Link to comment Share on other sites More sharing options...
dxstudios Posted February 14, 2022 Share Posted February 14, 2022 i was searching for similar kind of lisp, it almost saved my half day work... Tons of Thanks Bigal for the code & being reason for my smile Eagerly awaiting for the complete code. Quote Link to comment Share on other sites More sharing options...
