nzoro99 Posted January 19, 2022 Share Posted January 19, 2022 Hello, I'm back to school in Autolisp discipline. Your help will be greatly appreciated, as I'M DIGGING in this issue for last 48 hours without success. Here is the code for selecting viewport and by next step selecting only objects within that viewport. I want to do some slight modifications to code. I want to iterate through viewports automatically in paper space in order to select all objects and ("do whatever I want with those objects" - that's the future plan). For now I would like to pass the selection set to the command or function.(not clear to me due to the luck of experience and knowledge). The selection set to pass to main code is "rrr". I read the description of the script. It didn't help me (setq aa (ssget "_x" (list '(0 . "VIEWPORT")))) (setq Ent1 (ssname aa 0)) (setq b2 (car (entget Ent1))) (setq sss (ssadd)) ; Sets ss to a null selection set. (ssadd Ent1 sss) (setq rrr (ssadd Ent1 sss)) Main code ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpc () (vpsel "C") (princ) ) (defun c:vpw () (vpsel "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpsel (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) (if (= (getvar "tilemode") 0) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (if (= (getvar "cvport") 1) (if (and (= (getvar "cmdactive") 0) (/= (setq ss (ssget ":E:S" '((0 . "VIEWPORT")))) nil) ) (progn (setq ent (ssname ss 0)) (setq vpno (dxf 69 (entget ent))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ) (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) ) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget ent)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object ent)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) (progn (setq pl (entget (dxf 340 (entget ent)))) (setq nlist nil) (foreach x pl (if (eq 10 (car x)) (setq nlist (cons (trans (cdr x) 3 2) nlist)) ) ) (setq ss1 (ssget (strcat typ "P") nlist)) ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ) ) (setq ss nil ss1 nil) ) (princ) I'm relieved because I know I will get some help....Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Linh Posted January 19, 2022 Share Posted January 19, 2022 Hi, This line ask user to select a viewport on screen. If you already have the viewport (iterate through your viewport selection set), you got to skip this step, and put your viewport directly in (if (and (= (getvar "cmdactive") 0) (/= (setq ss (ssget ":E:S" '((0 . "VIEWPORT")))) nil) ) Replace ;replace this: (setq ent (ssname ss 0)) ;with this: (setq ent yourviewporthere) Also the vpsel function pass the result to the grip selection, then nullify the result at the end (setq ss nil ss1 nil) While you want to get the result, so, you got to comment out that line, and take the ss1 result out of the function, merge it to your rrr selection 2 Quote Link to comment Share on other sites More sharing options...
nzoro99 Posted January 21, 2022 Author Share Posted January 21, 2022 Linh, Thank you a lot for the answer. It works half way. I forgot to mention that "rrr" selection is for other lisp that calls vsel and vsp. I don't want one lisp for my task I want two. I will take my time for figuring it out by your great tip. I just thought that,s its not nice to delay a "Thank you" for your analysis. Quote Link to comment Share on other sites More sharing options...
nzoro99 Posted January 22, 2022 Author Share Posted January 22, 2022 (edited) Trial and error...Crime and Punishment Here is the updated code: ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpc () (vpsel "C") (princ) ) (defun c:vpw () (vpsel "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpsel (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) ;;; (if (= (getvar "tilemode") 0) ;;; (progn ;;; ;;; (if (= (getvar "cvport") 1) ;;; (if (and (= (getvar "cmdactive") 0) ;;; (/= (setq ss (ssget ":E:S" '((0 . "VIEWPORT")))) nil) ;;; ) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (setq aa (ssget "_x" (list '(0 . "VIEWPORT")))) (setq ent (ssname aa 0)) ;;; ;;; (setq ent rrr) ;;; (setq ent (car (entget Ent1))) (setq vpno (dxf 69 (entget ent))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ;;; ) (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget ent)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object ent)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) (progn (setq pl (entget (dxf 340 (entget ent)))) (setq nlist nil) (foreach x pl (if (eq 10 (car x)) (setq nlist (cons (trans (cdr x) 3 2) nlist)) ) ) (setq ss1 (ssget (strcat typ "P") nlist)) ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ;;; (setq ss nil ss1 nil) ;;; (setq sss (ssadd)) ;;; (ssadd ent sss) ;;; (setq rrr (ssadd ss1 sss)) ) (princ) I got stuck on this line: it produces an error Please help. Basically looking for tutor. I will do my homework:) It highlight the viewport but doesn't select it. Going through each line and checking data. Error on this line: (setq pl (entget (dxf 340 (entget ent)))) Edited January 22, 2022 by nzoro99 Quote Link to comment Share on other sites More sharing options...
Linh Posted January 22, 2022 Share Posted January 22, 2022 I think the topic name should be changed to something relate to "Select All Entities Within Viewport" or so. I can't try debug your code but I see: (setq aa (ssget "_x" (list '(0 . "VIEWPORT")))) (setq ent (ssname aa 0)) You select all viewport in the layouts but instead of loop through each viewport, you set the ent to the first item in the selection set. Firstly, better rename "ent" to "viewport" or "vp" to clarify the code. Second, the aa can be empty so the (ssname aa 0) returns error. (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) Few lines next, you drop the ent's viewport value and get the new value from activeviewport of the activedocument ad. So the (setq aa (ssget ...)) lines are useless, all the retrieved values are thrown away. In the original code, the programmer takes care of 2 cases: 1. is in a layout, paper space 2. is in a layout, but in mspace, (the cursor is within a viewport) For the viewport (ent), it also has 2 cases: + normal viewport: its boundary is a rectangle + clipped viewport: its boundary is some polyline, that is what this code is all about: (setq pl (entget (dxf 340 (entget ent)))) if error raises, try debug by put to watch, ent, (entget ent), (dxf 340 (entget ent)) to see anything is nil Just curious, is there in the world a kind of homework in AutoLisp? I am self taught (actually the web taught me), and I never know there is Autolisp study in any school Quote Link to comment Share on other sites More sharing options...
nzoro99 Posted January 22, 2022 Author Share Posted January 22, 2022 "Select All Entities Within Viewport" , I agree its a better name Quote You select all viewport in the layouts but instead of loop through each viewport, you set the ent to the first item in the selection set. Yes the loop will be later, for now I want any of 2 viewports to be selected. Quote Firstly, better rename "ent" to "viewport" or "vp" to clarify the code. Done. Quote Second, the "aa" can be empty aa result (entget vp) - result is, ((-1 . <Entity name: 14d67bf58d0>) (0 . "VIEWPORT") (330 . <Entity name: 14d03befec0>) (5 . "335") (100 . "AcDbEntity") (67 . 1) (410 . "Layout1") (8 . "G-ANNO-NPLT") (100 . "AcDbViewport") (10 -306.971 81.0516 0.0) (40 . 155.262) (41 . 128.7) (68 . 2) (69 . 3) (12 21977.9 5012.98 0.0) (13 0.0 0.0 0.0) (14 0.0 0.0 0.0) (15 0.0 0.0 0.0) (16 0.0 0.0 1.0) (17 0.0 0.0 0.0) (42 . 0.0) (43 . 0.0) (44 . 0.0) (45 . 12870.0) (50 . 0.0) (51 . 0.0) (72 . 1000) (90 . 32768) (1 . "") (281 . 0) (71 . 1) (74 . 1) (110 0.0 0.0 0.0) (111 1.0 0.0 0.0) (112 0.0 1.0 0.0) (79 . 0) (146 . 0.0) (170 . 0) (61 . 5) (348 . <Entity name: 14d03befaf0>) (292 . 1) (282 . 1) (141 . 0.0) (142 . 0.0) (63 . 250) (421 . 3355443)) (dxf 340 (entget ent)) - result is, nil ( there is no dxf for 340) ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpc () (vpsel "C") (princ) ) (defun c:vpw () (vpsel "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpsel (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) ;;; (if (= (getvar "tilemode") 0) ;;; (progn ;;; ;;; (if (= (getvar "cvport") 1) ;;; (if (and (= (getvar "cmdactive") 0) ;;; (/= (setq ss (ssget ":E:S" '((0 . "VIEWPORT")))) nil) ;;; ) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (setq aa (ssget "_x" (list '(0 . "VIEWPORT")))) (setq vp (ssname aa 0)) ;;; ;;; (setq ent rrr) ;;; (setq ent (car (entget Ent1))) (setq vpno (dxf 69 (entget vp))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ;;; ) (setq vp (vlax-vla-object->ename (vla-get-activepviewport ad))) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget vp)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object vp)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) (progn (setq pl (entget (dxf 340 (entget vp)))) (setq nlist nil) (foreach x pl (if (eq 10 (car x)) (setq nlist (cons (trans (cdr x) 3 2) nlist)) ) ) (setq ss1 (ssget (strcat typ "P") nlist)) ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ;;; (setq ss nil ss1 nil) ;;; (setq sss (ssadd)) ;;; (ssadd ent sss) ;;; (setq rrr (ssadd ss1 sss)) ) (princ) Thank you! Quote Link to comment Share on other sites More sharing options...
Linh Posted January 22, 2022 Share Posted January 22, 2022 (edited) + aa is not empty, but there is case your user has a drawing without any viewport, and aa is empty. Your software must take care all the cases. + if the 340 dxf is nil, the viewport is not clipped. It should fall into the first "if condition" above: (if (= (vla-get-clipped (vlax-ename->vla-object vp)) :vlax-false ) why it fell to the 2nd condition, i don't know I also note that if you have 3 viewport, can you highlight entities in all 3 viewports? I think AutoCAD only allow 1. Anyway, if your purpose is get the entities, not highlight them, then ok. You can get list of entities from everywhere in the database. Edited January 22, 2022 by Linh Quote Link to comment Share on other sites More sharing options...
nzoro99 Posted January 22, 2022 Author Share Posted January 22, 2022 (edited) Linh thank you, It worked ;;;---------------------------------------------------------------------------; ;;; ;;; vpsel.lsp ;;; ;;; By Jimmy Bergmark ;;; Copyright (C) 1997-2006 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com ;;; ;;; 2000-04-14 - First release ;;; Tested on AutoCAD 2000 ;;; ;;;---------------------------------------------------------------------------; ;;; DESCRIPTION ;;; ;;; Select all visible objects in selected or active paperspace viewport ;;; Works transparently when in modelspace and for polygonal viewports too ;;; Example1: ERASE ALL R 'VPC >>> Erase all in model except what is visible ;;; Example2: (command "erase" "all" "r" (c:vpc) "") ;;; Example3: VPC ERASE >>> VPC is run previous the command and the objects ;;; are also in previous selection set ;;; ;;; c:vpc - select all visible objects with crossing in viewport ;;; c:vpw - select all visible objects with window in viewport ;;;---------------------------------------------------------------------------; (defun c:vpttt () (vpselttt "C") (princ) ) (defun c:vpwttt () (vpselttt "W") (princ) ) (defun dxf (n ed) (cdr (assoc n ed))) (defun vpselttt (typ / ad ss ent vpno ok vpbl vpur msbl msur msul mslr ss1 pl nlist x n ) (vl-load-com) (setq ok t) (if (= (getvar "tilemode") 0) (progn (setq ad (vla-get-activedocument (vlax-get-acad-object))) (if (= (getvar "cvport") 1) (if (and (= (getvar "cmdactive") 0) (setq ss (ssget "_x" (list '(0 . "VIEWPORT")))) ) (progn (setq ent (ssname ss 0)) (setq vpno (dxf 69 (entget ent))) (vla-Display (vla-get-activepviewport ad) :vlax-true) (vla-put-mspace ad :vlax-true) (setvar "cvport" vpno) ) (progn (setq ok nil) ) ) (setq ent (vlax-vla-object->ename (vla-get-activepviewport ad))) ) (if (and ok (/= 1 (logand 1 (dxf 90 (setq ed (entget ent)))))) (progn (if (= (vla-get-clipped (vlax-ename->vla-object ent)) :vlax-false ) (progn (vla-getboundingbox (vla-get-activepviewport ad) 'vpbl 'vpur ) (setq msbl (trans (vlax-safearray->list vpbl) 3 2)) (setq msur (trans (vlax-safearray->list vpur) 3 2)) (setq msul (list (car msbl) (cadr msur))) (setq mslr (list (car msur) (cadr msbl))) (setq ss1 (ssget (strcat typ "P") (list msbl msul msur mslr)) ) ) (progn (setq pl (entget (dxf 340 (entget ent)))) (setq nlist nil) (foreach x pl (if (eq 10 (car x)) (setq nlist (cons (trans (cdr x) 3 2) nlist)) ) ) (setq ss1 (ssget (strcat typ "P") nlist)) ) ) (sssetfirst nil ss1) (if ss1 (setq n (sslength ss1)) (setq n 0) ) (princ n) (princ " found ") (if (and ss1 (= (getvar "cmdactive") 1)) ss1 ) ) ) ) ) (setq ss nil ss1 nil) ) (princ) The only thing is that, when I count my viewports it says 3 from 0-2, but I have only 2 in paper space under 0 and 2 We figure it out, but I didn't get how and why... Thank you!!! Edited January 22, 2022 by nzoro99 Quote Link to comment Share on other sites More sharing options...
Linh Posted January 23, 2022 Share Posted January 23, 2022 Well found. I haven't tested in Lisp, but coding in .NET I did also find 1 viewport in an empty layout, 2 viewports in 1 viewport layout.So I always skip the first viewport. Not sure why, maybe that is something about the layout. I guess the layout itself is a special viewport. Quote Link to comment Share on other sites More sharing options...
