Gradient hatch printing problem
I have a title block which contains a gradient hatch within a block. Unfortunately when I plot to one printer in plots a green retangular fill around the gradient hatch. If I plot to PDF then plot the PDF it's fine.:huh:
Does anybody have any ideas?
  • 4 weeks later...
This question has been moved to the "Hardware & Operating Systems" section.
Have you found a solution to this yet?
Does this only happen on one specific printer?
It sounds like the printer doesn't understand the information it's receiving from Autocad.
Do you have the most up to date plotter drivers for this printer?
No I haven't but we are chaging the printer next so it will be interesting to see if it happens with this one.
Yes it only happens with one particular printer.
I'll check the driver and report back.
  • 3 weeks later...
Did you check your printer's color inks?:)
We have had a new printer installed and it happens on this one as well. This is really starting to bug me. I've checked the drivers and they are up to date. I haven't checkd the cartridges as it's a colour laser printer also if it was a case of the wrong cartidge being installed it would mess up the rest of the drawing.
