weird insertion scale from tool pallete
michaeloureiro
hey all,
Blocks from a recent tool pallete are being inserted at a reduced scale. The units are set up correctly on both files.. Can anybody help?
This shouldn´t be happening figuring that there are blocks on the tool pallete that i haven´t changed recently.
I think i found the problem, when i try to insert the block, the factor value in the insert window is not set to 1, does anybody know how to change this?
