cat3appr Posted January 8, 2022 Posted January 8, 2022 I've searched in google for 10 minutes but I couldn't find this : i have a series of rectangles and I need to find their heading, without labelling. How do I do that? I have autocadMap. All the suggestions point out to open a survey tab which i don't have, or how to draw a line with bearing and distance, not useful. I need a tool or a lisp that by clicking on the object, or poliline, it will give you the heading / bearing, relative to the north. thank you Quote
BIGAL Posted January 9, 2022 Posted January 9, 2022 Label a pline could be simply modified to result in a BRG and distance, Instead of doing say (coomand "Text" do (alert (strcat brg distance etc)) I found one in a couple of minutes. Quote
eldon Posted January 9, 2022 Posted January 9, 2022 Of course with rectangles, each one has a bearing on each side, a total of four per rectangle. Quote
tombu Posted January 10, 2022 Posted January 10, 2022 Try this lisp by Kent Cooper https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-angle-of-line-tangent-to-a-point-in-the-spline/m-p/2608359#M285125 (defun c:TanAng (/ esel pt ent) (setq esel (entsel "\nPick Object for Tangent Angle at pick point: ") ent (car esel) pt (trans (osnap (cadr esel) "nea") 1 0) ); end setq (prompt (strcat "\nThe tangent angle is " (angtos(angle '(0 0 0) (trans (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtPoint ent pt)) 0 1 T))) ); end strcat ); end prompt (princ) ) Doesn't draw anything just returns tangent direction at a picked point on a line, arc, or polyline. Quote
