mahmoud saleh Posted January 5, 2022 Author Posted January 5, 2022 Just now, mahmoud saleh said: I WANT ALL LINE TO BE STRATIGHT LINES Quote
SLW210 Posted January 5, 2022 Posted January 5, 2022 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the correct forum. Quote
mhupp Posted January 5, 2022 Posted January 5, 2022 What your asking for would change the drawing dramatically. This will rotate lines @ midpoint with a +/- of 3.5 degrees from horizontal or vertical. Increase fuzz to meet your needs. ;; CAB 12.02.09 ;; Correct angles for lines with angles near 15 and 22.5 degrees +/- fuzz ;; Only LINES & only in Current Space ;; Only UnLocked Layers (defun c:test (/ filter ss layobj i ent lst angles fuzz obj ang midpt) (vl-load-com) (setq angles '(15 22.5) ; degree angles to test (0 through 90) fuzz 3.5 ; degree tolerance for adjustments of lines ) (setq angles (mapcar (function (lambda (x) (/ (* x pi) 180.0))) angles)) ; convert to radians (setq fuzz (/ (* fuzz pi) 180.0)) ; convert to radians (setq filter "") ;; filter locked layers (vlax-for layobj (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) (if (= (vla-get-lock layobj) ':vlax-true) (setq filter (strcat filter (vla-get-name layobj) ",")) ) ) (and (= filter "") (setq filter "*")) (setq ss (ssget "_X" '((0 . "LINE")(410 . "Model")))) (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (vla-StartUndoMark (vla-get-activedocument (vlax-get-acad-object))) (setq i -1) (while (setq ent (ssname ss (setq i (1+ i)))) (setq obj (vlax-ename->vla-object ent)) (setq ang (vla-get-angle obj)) (if (and (or (equal (setq re (rem ang (cadr angles))) 0.0 fuzz) (and (equal (setq re (rem ang (cadr angles))) (cadr angles) fuzz) (setq re (- re (cadr angles))) ) (equal (setq re (rem ang (car angles))) 0.0 fuzz) (and (equal (setq re (rem ang (car angles))) (car angles) fuzz) (setq re (- re (car angles))) ) ) (not (zerop re)) ) (progn (setq midpt (mapcar '(lambda (a b) (/ (+ a b) 2.)) (vlax-get obj 'startpoint) (vlax-get obj 'endpoint) ) ) (vla-rotate obj (vlax-3d-point midpt) (- re)) ) ) ) (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (princ) ) 1 Quote
ketxu Posted January 8, 2022 Posted January 8, 2022 On 1/5/2022 at 10:45 AM, mahmoud saleh said: So Superficial Question Quote
