Hi.
I have a lisp (see attched) that rotate and set the length of a prametric block.
I can't find a way to get the block attribute to rotate along with it....
I've looked for a tutorial but all I find is multiple blocks and attribute rotation using loops and I can't figure it out...
I need help with a rutine that set the attribute rotation in a block already selected and to a known value that is also known with in the lisp.
if it possible, I need help with rotating just one attribute - "QUANTITY" for example, so I will learn the basics first.
as it shown in the lisp,the block is already selected (obj), and the angle is also calculated and inserted in to a variable (ang).
thanks,
Ari.
(defun c:PipeLenBL (/ obj p1 di X Y insut )
  (setq obj (car (entsel "\nSelect Block ")))
  (setq p1 (getpoint "\nPoint 1: "))
  (setq p2 (getpoint "\nDistance: "))
  (setq di (distance p1 p2))
  (setpropertyvalue obj "d1" (rtos di 2 10))
  (setq insut (getvar "insunits"))
  if (= insut 4)
  (setpropertyvalue obj "QUANTITY" (rtos (* di 0.001) 2 3))
  if (= insut 6)
  (setpropertyvalue obj "QUANTITY" (rtos di 2 3))
  (setq ang (angle p1 p2))
 (setq X (getpropertyvalue obj "ScaleX"))
 (setq Y (getpropertyvalue obj "ScaleY"))
if (< (+ X Y) 1)
(setq ang (angle p2 p1))
(setpropertyvalue obj "Rotation" ang)
Edited by aridzv
15 hours ago, mhupp said:
Can you attach the block?
Yes, of course.
I've attached 2 files:
1. PVC PIPE DN63 PN10 ID-56 GRAY_DY1.dwg - the block it self.
2. Drawing1.dwg - a drawing that the block is inserted in to it.
Thanks!
*EDIT:
I found a way to do it with loop after Having read this excellent explanation By Lee MAC in this topic.
to keep it simple I have decided to change all the attributes rotation in this case instand of doing "if" statment to "Fish" just the "QUANTITY" attribute,
but still,is there a way to get to the specipic attribute with out creating a collection and then looping?
(setq obj (entlast)) ;selecting the block object
(setq obj1 (vlax-ename->vla-object obj)) ;converting the selected object to a vlax object
(foreach att (vlax-invoke Obj1 'GetAttributes) ;getting the block attributes in to a list/collection
 (vla-put-Rotation att ang)                    ;and looping through the block attributes and change the rotation
Drawing1.dwg PVC PIPE DN63 PN10 ID-56 GRAY_DY1.dwg
Edited by aridzv
setpropertyvalue only works on set properties of the object. use this on your block to see the properties.
;; Dump all methods and properties for selected objects
(defun C:DumpIt (/ ent)
  (if (setq SS (ssget))
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (vlax-Dump-Object (vlax-Ename->Vla-Object ent) t)
  (textscr)
Dynamic blocks can't be made by BricsCAD only edited. Thats why they came up with Parametric blocks.
If constrained properly their should be a section in the properties window (Ctrl + 1) shown here.
The parametric dimensions Are not attributes or dynamic so i don't know what to set.
I don't really use this type of block so maybe someone else can chime in.
Hi.
Actualy (for all of us,the Bricscad users... 🙂),
there is no problem to get to the parametric dimensions and set them as long as they are set as visible in the parametric block itself, see in my LSP:
(setpropertyvalue obj "d1" (rtos di 2 10)).
d1 is a visible parameter constraint for example.
the rest of the properties and attributes are the same as in Autocad.
Edited by aridzv
Ah I had set them to hidden. like I said don't really use parametric blocks. I know they have updated  alot since iv gotten BricsCAD. but that command still isn't working for me.
; error : no function definition <SETPROPERTYVALUE> ; expected FUNCTION at [eval]
Quote
is there a way to get to the specific attribute with out creating a collection and then looping?
Not really  you have to loop though them to get the one you want.
  (if (eq att "QUANTITY")
    (vla-put-Rotation att ang) ;rotates quantity att
O.K...
Maybe because the loop that rotate the attributes use VLA object.
in my code I assign the regular object to a VLA object just for the use of the attribute rotation,like this:
             (setq obj (entlast))                                ;; Get the pipe object
             (setq obj1 (vlax-ename->vla-object obj)) ;; set the pipe object to a VLA object for the attribute rotation function
and use obj1 in the attribute rotation function.
I also attched the full lsp file so you can check it out if you want.
Thanks For That!!
Ari.
PipeLenBL.lsp
Edited by aridzv
