Mapclean 20 minutes working and still...
hi all, I run mapclean on a 70MB dwg,  i have map21 , and a pretty powerful machine, i7 9700CPU, 64GB ram 3GHz
still, after 20 minutes, mapclean is there working....   shall I abort?  not sure when enough should be enough ?
Very powerful but it's not the kind of command you run on an entire drawing.
Here's some YouTube videos on using it. https://www.youtube.com/results?search_query=mapclean+command+autocad
I watch everything Jerry Bartels puts up, it would be a good one to start with.
As it's a Map 3D command this thread should be moved to https://www.cadtutor.net/forum/forum/47-map-3d/ by a moderator.
