NEED A FILLET LISP
mahmoud saleh
4 minutes ago, mhupp said:
Use the trim command with fence option. then use the pedit join
NO I WANT TO MAKE THEM LIKE THIS BUT OVER EACHOTHER ANT MAKE THEM FILLETS TOO
If I understand correct this has been asked before the answer may be over at forums/autodesk you end up with 3 plines all connected back to the same start point. Think electrical wire.
Sorry no idea what to google for.
ah I see i think @ronjonp made something like that it was for pipe line or something.
take a look this
wireruns.lsp
need theswamp id
http://www.theswamp.org/index.php?topic=45092.msg503931#msg503931
if you have coordinates of destinations
1. spread destinations by texts to cad by excel or manually
2. then draw some main line (main tray)
3. and draw minimum shortest line between text and main lines, by lisp (by ronjonp)
(defun c:MIN (/ _dxf _sl a b c e p s x)
  ;; RJP ≫ 2019-01-10
  (defun _sl (s) (cond ((= 'pickset (type s)) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))))
  (defun _dxf (c e) (cdr (assoc c (entget e))))
  (cond
    ((setq s (_sl (ssget)))
     (foreach x	s
       (if (wcmatch (_dxf 0 x) "TEXT") ;edited line
	 (setq b (cons (_dxf 10 x) b))
	 (and (= 'real (type (vl-catch-all-apply 'vlax-curve-getendparam (list x))))
	      (setq a (cons x a))
     (and a
	  b
	  (foreach p b
	    (setq c
		   (car	(vl-sort
			  (mapcar
			    '(lambda (x)
			       (list (setq c (vlax-curve-getclosestpointto x p)) (distance p c) (_dxf 8 x))
			    a
			  '(lambda (r j) (< (cadr r) (cadr j)))
	    (setq e (entmakex (list '(0 . "LINE") (cons 10 p) (cons 11 (car c)) (cons 8 (caddr c)))))
	    ;; This line below creates the right example comment out to get left
	    ;; (setq a (cons e a))
4. use mpedit command to make polyline
5. breaking all crossing polylines
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/break-all-polylines/m-p/2251689/highlight/true#M260485
add ucs w, ucs p line if you use this in custom ucs drawing
6. use wireruns lisp
then I edit this "to points" inserts(block) -> text
and If it is an alternative CAD other than AutoCAD, some modifications are required.
7. use fmp lisp (filletmultiplepolylines.lsp)
  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411/highlight/true#M412320
Edited by exceed
