gsc Posted December 20, 2021 Share Posted December 20, 2021 (edited) Hi, I have a working subroutine which lists a polyline on a certain layer in a block. ;;;------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ ;;; Get 4 or 6 x Spudcan Polygon Coordinates at WTG Location ;;;------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ (defun getspudcans ( ss / lst ent enx ) (setq lst (vlax-invoke (vlax-ename->vla-object ss) 'Explode)) (mapcar '(lambda (obj) (and (= (vla-get-objectname obj) "AcDbPolyline") (= (vla-get-layer obj) "JIV-SC_A") (setq pts (cons (mapcar 'cdr (vl-remove-if-not '(lambda (p) (= (car p) 10)) (entget (vlax-vla-object->ename obj)) ) ) pts ) ) ) ) lst ) (mapcar 'vla-delete lst) (car pts) ) However I want to list coordinates of objects stored in (possibly) 6 different layers: ("JIV-SC_A" "JIV-SC_B" "JIV-SC_C" "JIV-SC_D" "JIV-SC_E" "JIV-SC_F") This object is either a closed LWPOLYLINE or a CIRCLE Each layer contains max 1 polyline or 1 circle or is empty. IF object in one of these layers is a CIRCLE then List ((center coordinate) radius) IF object in one of these layers is a LWPOLYLINE then List (polyline coordinates) The resulting List must look like: ((list JIV-SC_A) (list JIV-SC_B) (list JIV-SC_C) (list JIV-SC_D)) What is the most efficient way to do this? Edited December 20, 2021 by gsc Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 20, 2021 Share Posted December 20, 2021 Don't know how your defining SS but it would be easier to filter there. (setq SS (ssget '((0 . "CIRCLE,*POLYLINE") (8 . "JIV-SC_A,JIV-SC_B,JIV-SC_C,JIV-SC_D")))) run a cond (= (vla-get-objectname obj) "AcDbPolyline") or (= (vla-get-objectname obj) "AcDbCircle") depending on if its a polyline or circle (setq lay (vla-get-layer obj)) (setq lay (cons ((center coordinate) radius))) (setq lay (cons (polyline coordinates))) Quote Link to comment Share on other sites More sharing options...
