Kurpulio Posted December 16, 2021 Share Posted December 16, 2021 Hello, I got this LISP for automatically placing texts with incremental number vaues (e.g. for room numbering) (from here https://www.youtube.com/watch?v=5q6ssb3p_tk ) It requires command 'TIT' By default it places texts with '2.5' height, which is always too small compared to my drawing. It'd be awesome if this .lsp would use some fixed text height value which i can set to what i need. (like before i use the .lsp i open it in notepad and change the value) I tried to set use command 'textsize' prior running the list, but somewhy texts placed by the lisp always remained 2.5 Thanks Numbering_TIT.lsp Quote Link to comment Share on other sites More sharing options...
exceed Posted December 16, 2021 Share Posted December 16, 2021 (edited) entmake txt use (cons 40 txt) cons 40 = textsize property variable txt = (getvar dimtxt) x (getvar dimscale) so, I guess replace every (cons 40 txt) to (cons 40 (getvar "textsize")) it can be change to textsize variable you input Edited December 16, 2021 by exceed Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted December 16, 2021 Share Posted December 16, 2021 Like this? ;;; TX+INTEGERS+TX (defun c:tit (/ p n ni pref suff nns ntx ntxx oecho osn ds th txt) (setq oecho (getvar "cmdecho") osn (getvar "osmode") ) (if (= 0 (getvar "dimscale"))(setq ds 1.0)(setq ds (getvar "dimscale"))) (setq th (getvar "dimtxt")) (setq txt (getreal "\nText Height: ")) (setvar "cmdecho" 0) (setvar "osmode" 0) (if nn (setq nn (fix nn)) (setq nn 1) ) (if (= nn 0)(setq nn 1)) (princ "\n Increment numbers by < ") (princ nn) (princ " >? : ") (setq ni (getint)) (if (= ni nil) (setq ni nn) (setq nn ni) ) (if np (setq np (fix np)) (setq np nn) ) (princ "\n Start or continue with number < ") (princ np) (princ " >? : ") (setq n (getint)) (if (= n nil) (setq n np) (setq np n) ) (setq nns (itoa n)) (princ "\n Prefix text < ") (princ pre) (princ " >? or <.> for none: ") (setq pref (getstring t)) (if (= pref ".") (progn (setq pre nil) (setq pref nil) ) (progn (if (= pref "") (setq pref pre) (setq pre pref) ) (if pref (setq ntx (strcat pref nns)) ) ) ) (princ "\n Suffix text < ") (princ suf) (princ " >? or <.> for none: ") (setq suff (getstring t)) (if (= suff ".") (progn (setq suf nil) (setq suff nil) ) (progn (if (= suff "") (setq suff suf) (setq suf suff) ) (if suff (if pref (setq ntxx (strcat pref nns suff)) (setq ntxx (strcat nns suff)) ) ) ) ) (setq p (getpoint "\n Insert: ")) (setq oecho (getvar "cmdecho")) (while p (if suff ;(command "text" "j" "mc" p "" "" ntxx) (entmake (list (cons 0 "TEXT") (cons 10 p) (cons 11 p) (cons 1 ntxx) ; actual text (cons 7 (getvar "TEXTSTYLE")) (cons 40 txt) (cons 72 4) ) ) (if pref ;(command "text" "j" "mc" p "" "" ntx) (entmake (list (cons 0 "TEXT") (cons 10 p) (cons 11 p) (cons 1 ntx); actual text (cons 7 (getvar "TEXTSTYLE")) (cons 40 txt) (cons 72 4) ) ) ;(command "text" "j" "mc" p "" "" n) (entmake (list (cons 0 "TEXT") (cons 10 p) (cons 11 p) (cons 1 n); actual text (cons 7 (getvar "TEXTSTYLE")) (cons 40 txt) (cons 72 4) ) ) ) ) (setq p (getpoint "\n Next number location: ") n (+ ni n) nns (itoa n) np n ) (if suff (if pref (setq ntxx (strcat pref nns suff)) (setq ntxx (strcat nns suff)) ) ) (if pref (if suff (setq ntxx (strcat pref nns suff)) (setq ntx (strcat pref nns)) ) ) ) (setvar "cmdecho" oecho) (setvar "osmode" osn) (princ) ) (princ "\n Type > TIT < to insert text with ascending integers.") 1 Quote Link to comment Share on other sites More sharing options...
Kurpulio Posted December 16, 2021 Author Share Posted December 16, 2021 8 minutes ago, Isaac26a said: Like this? Thank you !! exactly this way this .lsp is much more convenient to use than Express Tools's tcount command Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted December 16, 2021 Share Posted December 16, 2021 3 minutes ago, Kurpulio said: Thank you !! exactly this way this .lsp is much more convenient to use than Express Tools's tcount command You're welcome Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 16, 2021 Share Posted December 16, 2021 I would recommend using http://www.lee-mac.com/numinc.html a lot more and easier to customize. 1 Quote Link to comment Share on other sites More sharing options...
