Tim64545665 Posted December 14, 2021 Share Posted December 14, 2021 Hi All, I have received a 3d tin in Autocad (3d triangles) from a surveyor and i would like to cut 2d sections out. I was wondering if there is a way to possible convert the 3d triangles in a surface possibly and then draw a line to cut out a elevation/section through that surface, so i could essentially have a surface line and then add my own datum. Thanks in advanced. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 14, 2021 Share Posted December 14, 2021 I have moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 14, 2021 Share Posted December 14, 2021 The simple answer is that you can get a section from a line crossing 3dfaces, it is something I did like 30 years ago, for house elevations it worked on 3d contour lines. You need to convert the 3d faces to lines, remove duplicates then can trim the lines revealing the end 3d pts which can be joined. Will see if can find I would Google should be out there. Found 3dface to lines by google that is step 1. Quote Link to comment Share on other sites More sharing options...
lrm Posted December 15, 2021 Share Posted December 15, 2021 (edited) If you are using vanilla AUtoCAD and not Civil 3D use the planesurf command with the Object option to convert the 3dfaces to surfaces then give the section command and specify the location of the sectioning plane as needed. Edited December 15, 2021 by lrm Quote Link to comment Share on other sites More sharing options...
Tim64545665 Posted December 15, 2021 Author Share Posted December 15, 2021 Thanks for you responses. I'm on vanilla AutoCAD I tried the planesurf command with little luck, perhaps I'm doing something wrong. Although looks like I can convert the faces to a surface easily using "convtosurface". Once the model is converted, I can use "sectionplane" with "Type" and "slice". I then reduce the size of the plane so it is thin and use command "sectionplanetblock" > select my section plane and click create. This method gives me a block of a section cut nicely with minimal trimming, just a few steps involved that I could reduce with lisp. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 15, 2021 Share Posted December 15, 2021 You might see if CadTools has what you need. 2 Quote Link to comment Share on other sites More sharing options...
f700es Posted December 15, 2021 Share Posted December 15, 2021 1 hour ago, SLW210 said: You might see if CadTools has what you need. WHAT???? TIL (today I learned)!!! Quote Link to comment Share on other sites More sharing options...
Tim64545665 Posted December 16, 2021 Author Share Posted December 16, 2021 TIL me too, this looks very helpful. Thanks for sharing! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 20, 2021 Share Posted December 20, 2021 I have posted it several times here. Too bad I no longer have it after the new computer. I guess some things I just won't be doing now. Quote Link to comment Share on other sites More sharing options...
