Giovannino60 Posted December 10, 2021 Posted December 10, 2021 In this block, how should I proceed to add a line, see the image with the red ellipse? Thank you Disegno1.dwg Quote
oliver07 Posted December 31, 2021 Posted December 31, 2021 Click Home tab Draw panel COGO drop-down COGO Input. In the COGO Input dialog box, select the Bearing/Distance routine. For the first point of an object, specify a starting point. Enter the quadrant (NE, SE, SW, NW). Enter the angle. 1 Quote
CyberAngel Posted January 3, 2022 Posted January 3, 2022 If you only want to add another piece of data, you could use ATTDEF to define a new attribute. 1 Quote
Giovannino60 Posted January 3, 2022 Author Posted January 3, 2022 I just want to add a line to write more words ... Quote
CyberAngel Posted January 3, 2022 Posted January 3, 2022 5 hours ago, Giovannino60 said: I just want to add a line to write more words ... Look up "multiline attribute." Or use the DDATTDEF command to create a multiline attribute. Or change the multiline property of an existing attribute. 1 Quote
