samifox Posted December 9, 2021 Posted December 9, 2021 HI im working with parametric constraint, having some difficulties to reach my goals, was hoping I can get help with in the image simple trapezoid profile armed with parametric constraint, first thing is that i need the magenta rectangle above the trapezoid remain in its initial length, right now when changing parameters d4,d5 and d1 cause it to stretch. i need d4 and d5 adjust the rectangle position along to trapezoid top rather than stretching it. how can i do that? have attached dwg tx s furom_post_1.dwg Quote
