Javier Perez Posted December 8, 2021 Share Posted December 8, 2021 Hi I have a couple of hexagon blocks tha I use on a dailiy basis, one is from 1 to 9, and the other is 10 and above. i had to make a second so as to keep the hezagon the same size as the first one, I also had to decreas the size of the the text to keep it inside of the hexagon. I would be very grateful if some one could convert this blocks to incrementally increase the number inside the block as it is placeed on the drawing. I have the block in a layerr a named designator with line weight of .040, and arial font. I am using windows 10 with autocad 2021 full version. Maybe a lisp program? Any help with this is greatly appriciated. Sincerely Javier DESIGNATOR.dwg DESIGNATOR 10.dwg Quote Link to comment Share on other sites More sharing options...
ronjonp Posted December 8, 2021 Share Posted December 8, 2021 Maybe THIS can help you. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 9, 2021 Share Posted December 9, 2021 (edited) Pt num bubble.lspMaybe this also. Edited December 9, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
