Lisp To Select Multiple Text and MText Values Entered
For example, there are texts containing area, m2, 50, door, etc. I could select them one by one thanks to QuickSelect, Text or MText, Contents and Wildcard Match, but I want to select them all at the same time like entering Area*, m2*, etc. and select all texts and mtexts containing those values like selecting them with wildcard match or a lisp to select text and mtext containing the values I want to select in the entire drawing, like if you select area:50m2, it would select area:75m2 or area 40m2 as well. Either one of these kinds of lips would help. Thanks in advance.
This will select/highlight any text that starts with "Area" or ends with "m2".
(defun C:seltxt (/ SS)
  (setq SS (ssget "_X" (list '(0 . "*TEXT") '(1 . "Area*,*m2") (cons 410 (getvar 'ctab)))))
  (sssetfirst nil ss)
Edited by mhupp
updated code.
  • Like 3
@mhupp as long as you are highlighting objects then I believe it would be much better to get the ones in current active space only than selecting all matching objects in the other invisible spaces.
  • Agree 1
Thinking more about this maybe it would be  better to let the user decide what to search for. or use both top for common terms and this for not so common terms. You also have to input the * for wild cards and use , if you going to search for more then one term.  its also important to note when typing the search terms you can't use spaces.
(defun C:selTxt (/ SS txt)
  (setq txt (getstring "\nSearch Text for Terms: ")) ;hit enter for defult options.
  (if (eq txt "")
    (setq txt "Area*,*m2") ;set defult search options here
  (if (setq SS (ssget "_X" (list '(0 . "*TEXT") (cons 1 txt) (cons 410 (getvar 'ctab)))))
    (sssetfirst nil ss)
    (prompt (strcat "\nText doesn't contain " txt))
Example
Search Text for: area*,*m2                           This would work like above lisp.
Search Text for: *area*                                  This would select text that has the word "area" in it.
Search Text for: *door                                   This would select text that ends with "door"
Search Text for: area*,*m2,*area*,*door    This would select all 3 examples text in one go.
Edited by mhupp
combined the two commands into one.
  • Like 2
  • Thanks 1
  (if (eq txt "")
    (sssetfirst nil ss)
Example
This lips is good, thanks. But, is there any way to enter multiple text, mtext values at the same time to select texts, mtexts containing either one of those values separately?
I'm not understanding. you can search for multiple values at once just use a , in between them.
Do you then want to cycle through the text that match the search one at a time? to edit them or something?
Can you explain more what you want to do.
I want to select text with different content I will enter and move or delete them, as they are not useful to me.
You can use a simple (while  and just add the txt to a string.
(setq str "")
(while (/=  "" (setq txt (getstring "\nType text Enter to stop ")))
(setq str (strcat str "," txt))
  • Like 3
(setq str "")
I couldn't make it work, but thanks.
This works for me, selects text with user input as BigAl suggested and MHupps first bit of code (slight modification to both, using "(getstring T....)" to allow for spaces in the text string and (cons 1 str) which mhupp uses n his second code)
(defun C:seltxt (/ SS str)
  (setq str "")
  (while (/=  "" (setq txt (getstring T "\nType text Enter to stop ")))
  (setq SS (ssget "_X" (list '(0 . "*TEXT") (cons 1 str) (cons 410 (getvar 'ctab)))))
  (sssetfirst nil ss)
Noting that this is case sensitive, not sure how to do it otherwise,  and it also accepts wold cards, search term Hello won't select 'Hello World' text in the drawing. but search Hello* should pick it up (and so should *llo wo*)
  • Like 3
  (setq str "")
  (sssetfirst nil ss)
This works great. Thank you all.
Not me, I just copied and pasted BigAl and Mhupp.....
  • 2 weeks later...
  (if (eq txt "")
    (sssetfirst nil ss)
Example
dear mate, can you add automatically delete those selected text at the end of this lisp ? if would be great
output of this routine is selection.
so, just add
(command "erase" )
before (princ), after ) in the last section
  • Agree 1
  • Thanks 1
so, just add
(command "erase" )
thanks mate.. working
