Steven P Posted December 3, 2021 Share Posted December 3, 2021 what happens if you try this? (defun c:testatall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq pagecount (PDFPageCount fn)) (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount (setq n (1+ n)) ) (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 I try the new code but the same Insertion Point; error: bad argument type: fixnump: nil (vl-load-com) (princ) (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) (defun c:testatall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq pagecount (PDFPageCount fn)) (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount (setq n (1+ n)) ) (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 so next try it without the line " (setq pt (getpoint "Insertion Point"));;prompt for insertion point here " - slowly narrowing it down to where the problem is Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 the same error Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 So your problem is going to be " (setq pagecount (PDFPageCount fn)) ", try the whole lot again but replace that with a 1 just to check. Unusual since PDFPageCount is one of Lee Macs, maybe complacency but I just assume they work perfectly or better - he hasn't failed me yet. Below will insert just 1 page. (vl-load-com) (princ) (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq pagecount 1) (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount ;; (while (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (polar pt 0.0 8.5)) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 Now work but insert only one page. The first code before the _countpage work too but need an esc to stop. Is any other way to fix the first code? The first code is ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq fn (getfiled "Select PDF File" "" "pdf" 8)) (setq n 1) (setq pt '(0.0 0.0 0.0));;prompt for insertion point here (while (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (polar pt 0.0 8.5)) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 Work in progress - narrowing down where the problem is. Could be that the result from PDFPagecount gives a string and not an integer.. make it an integer and it will work... I'll look at that idea later if you can't get a solution 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 ok Steven P .Look at it and tell me. Thanks Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 So you could try adding this function: (defun texttoint ( mytext / ) (if (= (type mytext) 'STR)(setq mytext (atof mytext))) ;;String to Real (if (= (type mytext) 'REAL)(setq mytext (fix (+ mytext (if (minusp mytext) -0.5 0.5))))) ;;From Lee Mac, real to Int mytext ) and change the line (setq pagecount ( PDFPageCount fn)) to (setq pagecount ( texttoint (PDFPageCount fn))) in the Atall function, see what that does. Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 Sounds like its not allowing you to pick a point. https://forums.autodesk.com/t5/autocad-forum/problem-with-getpoint-on-autocad-2015-when-the-function-is/td-p/5040722 try changing it to and see if it works. (setq pt '(0 0 0)) 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 He says he tried it without that, about 8 posts up, 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 (edited) Ah what i get for not refreshing was still on page 1 Edited December 3, 2021 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 I don't know how to do it.if someone can fix the code please help Thanks Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 4 minutes ago, prodromosm said: I don't know how to do it.if someone can fix the code please help Thanks (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun texttoint ( mytext / ) (if (= (type mytext) 'STR)(setq mytext (atof mytext))) ;;String to Real (if (= (type mytext) 'REAL)(setq mytext (fix (+ mytext (if (minusp mytext) -0.5 0.5))))) ;;From Lee Mac, real to Int mytext ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq spacing 8.5) ;; spacing between sheets in inches. Modify as required. (setq fn (getfiled "Select PDF File" "" "pdf" 8)) ;;fn: PDF File Name (setq pagecount ( texttoint (PDFPageCount fn))) ;; Number of pages from function PDFPageCount (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (list (+ (car pt) spacing) (cadr pt) (caddr pt))) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 Insertion Point; error: bad argument type: fixnump: nil what is going on with this code ? Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 3, 2021 Share Posted December 3, 2021 http://lee-mac.com/errormessages.html bad argument type: fixnump: <value> A function requiring an integer argument has been passed an argument of incorrect data type with the value noted in the error message. The point "pt" isn't being set by getpoint for some reason. I have a feeling whats going on. you have old/duplicate code somewhere with the same command that is not setting pt. when you type atall its running that code instead. try changing the command and see if it works. (defun c:atall (/ fn n pt) change to (defun c:TEST (/ fn n pt) 1 Quote Link to comment Share on other sites More sharing options...
StevJ Posted December 3, 2021 Share Posted December 3, 2021 (edited) 43 minutes ago, Steven P said: (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun texttoint ( mytext / ) (if (= (type mytext) 'STR)(setq mytext (atof mytext))) ;;String to Real (if (= (type mytext) 'REAL)(setq mytext (fix (+ mytext (if (minusp mytext) -0.5 0.5))))) ;;From Lee Mac, real to Int mytext ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq spacing 8.5) ;; spacing between sheets in inches. Modify as required. (setq fn (getfiled "Select PDF File" "" "pdf" 8)) ;;fn: PDF File Name (setq pagecount ( texttoint (PDFPageCount fn))) ;; Number of pages from function PDFPageCount (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (repeat pagecount (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (list (+ (car pt) spacing) (cadr pt) (caddr pt))) ) (command);cancel out of index pdf underlay (princ);quietly exit ) More information in the hope that it will be helpful. If landscape pages are rotated so that all pages are now portrait, all pages are inserted without overlap. The original PDF, with a first page in landscape orientation, stops, meaning program terminates, after inserting the first page. Steve Edited December 3, 2021 by StevJ clarification Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 something else that might help pinpoint the error could be to put this after the 'getpoint' line: Should show you in the command line all the variables used up to that point (princ fn) (princ " - ") (princ pagecount) (princ " - ") (princ pt) (princ n) 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted December 3, 2021 Share Posted December 3, 2021 Insertion PointC:\Users\Admin\Desktop\test.pdf - nil - (121.389 176.454 0.0)1; error: bad argument type: fixnump: nil This is the new error (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun texttoint ( mytext / ) (if (= (type mytext) 'STR)(setq mytext (atof mytext))) ;;String to Real (if (= (type mytext) 'REAL)(setq mytext (fix (+ mytext (if (minusp mytext) -0.5 0.5))))) ;;From Lee Mac, real to Int mytext ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun PDFPageCount ( filename / fob fso mat reg res str ) ;; Translation by Lee Mac of the VBScript code by Chanh Ong ;; found at http://docs.ongetc.com/?q=content/pdf-pages-counting-using-vb-script ;; ;; Call with fully qualified filename of PDF file: ;; (_PDFPageCount "C:\\Folder\\Filename.pdf") ;; ;; Returns integer describing number of pages in specified PDF file (if (and (setq filename (findfile filename)) (eq ".PDF" (strcase (vl-filename-extension filename))) ) (vl-catch-all-apply (function (lambda ( / _ReadAsTextFile _CountPage ) (defun _ReadAsTextFile ( fso fn / fob str res ) (setq fob (vlax-invoke fso 'getfile fn) str (vlax-invoke fso 'opentextfile fn 1 0) res (vlax-invoke str 'read (vlax-get fob 'size)) ) (vlax-invoke str 'close) (vlax-release-object str) (vlax-release-object fob) res ) (defun _CountPage ( rgx str / mat pag ) (vlax-put-property rgx 'pattern "/Type\\s*/Page[^s]") (vlax-put-property rgx 'ignorecase actrue) (vlax-put-property rgx 'global actrue) (setq mat (vlax-invoke rgx 'execute str) pag (vlax-get mat 'count) ) (vlax-release-object mat) (if (zerop pag) 1 pag) ) (setq fso (vlax-create-object "Scripting.FileSystemObject") reg (vlax-create-object "VBScript.RegExp") str (_ReadAsTextFile fso filename) res (_CountPage reg str) ) ) ) ) ) (foreach obj (list str fob mat fso reg) (vl-catch-all-apply 'vlax-release-object (list obj)) ) res ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Insert all pdf pages of a file ;;assumes single row at 8-1/2" spacing ;;Demo only ;;D.C. Broad, Jr. 2012 ;;Warning: Once started, cannot be escaped from till done. (defun c:atall (/ fn n pt) (setq spacing 8.5) ;; spacing between sheets in inches. Modify as required. (setq fn (getfiled "Select PDF File" "" "pdf" 8)) ;;fn: PDF File Name (setq pagecount ( texttoint (PDFPageCount fn))) ;; Number of pages from function PDFPageCount (setq n 1) (setq pt (getpoint "Insertion Point"));;prompt for insertion point here (princ fn) (princ " - ") (princ pagecount) (princ " - ") (princ pt) (princ n) (repeat pagecount (not (vl-catch-all-error-p ;avoid error trigger (vl-catch-all-apply '(lambda () (command "-pdfattach" fn (itoa n) pt 1 0) ) nil ) ) ) (setq n (1+ n)) (setq pt (list (+ (car pt) spacing) (cadr pt) (caddr pt))) ) (command);cancel out of index pdf underlay (princ);quietly exit ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 3, 2021 Share Posted December 3, 2021 Yup, that helps. So the message, I asked if you could put in something to give us details. Insertion Point - all OK, it asks for insertion point, the LISP works to that point OK C:\Users\Admin\Desktop\test.pdf - the file you selected nil - this is the problem - this is from 'pagecount' (121.389 176.454 0.0) - insertion point, all OK 1 - as expected ; error: bad argument type: fixnump: nil - error telling us that something expected to be a number isn't a number - that 'nil' above Maybe try a different PDF just in case that is the problem - that's the only thing that should be different to what you and I are doing. If it all goes wrong replace the (setq pagecount ...) line with (setq pagecount (getint "Enter Number of Pages")) to add the number of pages manually, Quote Link to comment Share on other sites More sharing options...
