LISP to draw Spline or 3D Pline from Points or Lines
I am after a LISP to draw Spline or 3D Pline from Points or Lines as in the attached drawing.
Any help is greatly appreciated. Cheers!
Lines2Spline-.zip
give this a try:
(vl-load-com)
;;; to make a 3d polyline*******************************************
(defun c:pol (/ adoc spc ss cnt plst 3dline)
(setq adoc(vla-get-activedocument(vlax-get-acad-object)))
(setq spc(vlax-get adoc
(if (equal (getvar "cvport") 1)
'PaperSpace
'ModelSpace
);_if
);_setq
(setq ss (ssget '((0 . "POINT"))));_select only point objects
(if ss
(setq cnt 0);_loop counter
(setq plst '());_empty list
  (while (< cnt (sslength ss))
(setq plst (cons(cdr(assoc 10(entget (ssname ss cnt))))plst));_make point list
(setq cnt (1+ cnt));_incerase counter
    );_while
(setq 3dline (vla-add3dpoly ;_make 3d polyline
      spc
      (vlax-safearray-fill
 (vlax-make-safearray vlax-vbDouble
 (cons 0 (1- (length (apply 'append plst)))))
      );_setq add 3dpoly
);_progn
);_if
  );_defun
;;; to make a 3d  spline******************************************
(defun c:spl (/ adoc spc ss cnt plst 3dline stpt ept)
'PaperSpace
'ModelSpace
);_if
);_setq
(if ss
    );_while
(setq stpt (vlax-3d-point '(0.0 0.0 0.0)));_start pt for spline
(setq ept (vlax-3d-point '(0.0 0.0 0.0)));_end pt for spline
(setq cline (vla-addspline
      spc
      stpt
      ept
      );_setq add 3d spline
);_progn
);_if
  );_defun
^ JohnM, pardon my stupidity, but how does the program know in which order to follow the points?
Haven't tried it but looks good.
..don't you need a test to see if points are in correct order-depending on how points are created their order in the selection set may not be along the polyline..
**oops too slow with the same question :)
Well you have a good point about the points, so let me point out that you should make it a point to have the points created in the correct order.
You could write a routine that puts them in order but depending on what you are exactly doing it could get very complex and I don’t believe you could cover all the ways it could be calculated.
Hey Phiphi,
If the information can come from a file containing X,Y and Z values have you considered using a script file?
For a 3d Poly
;;Turn off osnap
osmode
0
;;start the 3d polyline command
3dpoly
60.8628,72.8892,0.6110
56.3497,70.7362,0.6110
51.8366,68.5842,0.6110
47.3235,66.4322,0.6110
42.9999,63.9422,0.6110
39.4092,60.4812,0.6110
36.7864,56.2392,0.6110
35.2290,51.4962,1.0850
33.9393,46.6652,1.3060
32.6496,41.8352,0.7110
31.3600,37.0042,0.7110
29.6437,32.3202,0.7110
26.8343,28.1992,0.6890
23.0929,24.9022,0.6590
18.6520,22.6332,0.6290
13.7887,21.5262,0.5560
8.8277,20.9022,0.4150
3.8668,20.2782,0.2720
-1.0941,19.6542,0.1450
-6.0551,19.0312,0.0650
-11.0160,18.4072,0.0000
For a spline
;;Turn off osnap
osmode
0
spline
Never using a script file, but will learn and try. Thanks you, Jammie. PP.
helo JohnM
can you improve the lisp to draw 3dpolyline from the file (n x y x) n=number of 3dpolyline x y z three dimension of the point
thanks for your efforts
LOL I see what you did there. Didn't really notice it last time.
i try the script file it is good but not suffecient
you see the lisp submited by johnm it writes coordinates of the 3dpolyline withe a name at first so if you have mor than 3dpoly that mean you have a text file like this for example:
1,-267791.23,160628.28,1139.72
1,-267795.60,160626.53,1139.95
1,-267799.98,160625.54,1138.60
1,-267803.91,160625.17,1135.68
1,-267808.80,160625.77,1135.23
1,-267813.01,160627.20,1137.30
1,-267816.31,160629.19,1140.16
2,-267684.33,160614.02,1134.51
2,-267689.24,160613.59,1133.70
2,-267694.19,160613.32,1133.06
2,-267699.17,160613.24,1132.65
2,-267704.16,160613.12,1132.34
2,-267709.14,160612.82,1132.01
2,-267714.12,160612.62,1131.63
2,-267719.09,160612.91,1131.18
2,-267723.94,160614.02,1130.68
2,-267728.69,160615.48,1130.19
2,-267733.57,160616.48,1129.78
2,-267738.55,160616.49,1129.49
2,-267743.48,160615.72,1129.26
2,-267748.30,160614.43,1128.99
3,-267731.10,160605.46,1130.29
3,-267736.04,160604.79,1129.94
3,-267740.99,160604.15,1129.58
3,-267745.94,160603.53,1129.20
3,-267750.89,160602.94,1128.83
3,-267755.84,160602.37,1128.45
3,-267760.80,160601.84,1128.08
3,-267765.76,160601.34,1127.72
3,-267770.73,160600.88,1127.38
3,-267775.70,160600.46,1127.05
3,-267780.68,160600.09,1126.75
3,-267785.66,160599.73,1126.49
3,-267790.63,160599.25,1126.24
3,-267795.57,160598.51,1126.01
3,-267800.44,160597.41,1125.80
3,-267805.26,160596.11,1125.61
the number means 3dpolyline number
so my request to use this file draw 3dpolyline with a number
thanks
