nicolas Posted November 24, 2021 Posted November 24, 2021 Hi, Here is a project where I will like to receive some comments/feedback especially with respect to Raised Concrete Platform as there are new upstand beam here and there and there is a need to have platform to go from one room to another. The TV Room and Living are already very small spaces + the raised concrete platform. I will also like to get the specifications for slope to Balcony floor and ways to prevent rain water from going from one floor down to another. There is a column next to the balcony and I can have 1 down pipe and having 45 degree pipe getting into it but are there other solution to it? Also I have casting the slab in 1 go meaning same level slab between the living areas and the balcony but with a kicker under the wall and door between the living and the balcony. Is a 100 mm. kicker enough? Your comments and advice will be great. Thank you all in advance. Small TV Room and Living.dwgFetching info... Uprised Concrete Floor.pdfFetching info... Front Elevation.pdfFetching info... Section B-B.pdfFetching info... Slope to Drain Rain Water from Balcony.pdfFetching info... Quote
