p2pnex Posted November 21, 2021 Share Posted November 21, 2021 How to change cell formatting in Excel to text via lisp, and change cell color in the first line, before writing the list. (defun c:test ( / *error* arq A B C o) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end")) (princ (strcat "\nError: " errmsg))) (if arq (close arq)) (princ)) (setq narq (getfiled "Selecione o Nome e Local" "PLANILHA TESTE" "csv" 1)) (setq arq (open narq "w")) (write-line "Col1;Col2;Col3;Col4;Col5;Col6" arq ) (setq A '(("0001" "aa" "01-01" "x001") ("0002" "aa" "002" "x002") ) B '(("0001" "bb" "c01" "d002")) C A) (foreach i B (if (setq o (assoc (car i) A)) (setq C (subst (append o (cdr i)) o C)))) (foreach e C (write-line (apply 'strcat (mapcar '(lambda (x) (strcat x ";")) e)) arq)) (if arq (close arq)) (princ))) Quote Link to comment Share on other sites More sharing options...
kirby Posted November 24, 2021 Share Posted November 24, 2021 Setting excel range or cell properties is done using the 'vlax-put-property' command. MS Excel VBA online help is your friend for finding the names of properties of the Range or Cell object, and of the many enumerations used in Excel. See attached code snippet (part of a larger routine that inserts and formats a list of data into a specified Worksheet at the specified row and column) ; Data type codes ; vlax-make-variant constants ; https://documentation.help/AutoLISP-Functions/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-6806.htm ; Some codes Empty = 0, Null = 1, Integer = 2, Long = 3, Single = 4, Double = 5, String = 8, Object = 9, Boolean = 11 (cond ((eq DataType "R") (setq TypeCode 5)) ; vlax-vbDouble ((eq DataType "I") (setq TypeCode 3)) ; vlax-vbLong ((eq DataType "S") (setq TypeCode 8)) ; vlax-vbString ) ; Justification ;https://docs.microsoft.com/en-us/office/vba/api/excel.xlhalign (cond ((eq DataJust "L") (setq JustCode -4131)) ; xlLeft ((eq DataJust "C") (setq JustCode -4108)) ; xlCenter ((eq DataJust "R") (setq JustCode -4152)) ; xlRight ) (setq xlcell nil) (setq xlcell (xlgetcellrange MySheet CellIndex)) ; Format. Specify this first so that any Text strings do not get covnerted to numbers my mistake (e.g. Handle '20e87', excel will try to converr to real 2.0e88 (if DataFormat (vlax-put-property xlcell "NumberFormat" DataFormat) ) ; Data type (cond ((member DataType (list "R" "I" "S")) (vlax-put-property xlcell 'value2 (vlax-make-variant DataValue TypeCode)) ) ((eq DataType "F") (vlax-put-property xlcell "Formula" DataValue) ) ) ; Justification (if DataJust (vlax-put-property xlcell "HorizontalAlignment" JustCode) ) ; Font bolding (setq MyFont (vlax-get-property xlcell "Font")) (cond ((eq FontBold 1) (vlax-put-property MyFont "Bold" (vlax-make-variant 1 11))) ; boolean 1=true ((eq FontBold 0) (vlax-put-property MyFont "Bold" (vlax-make-variant 0 11))) ; boolean 0=false ) ; Colour (if CellColourIndex (vlax-put-property (vlax-get-property xlcell "Interior") "Colorindex" (vlax-make-variant CellColourIndex)) ) 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 25, 2021 Share Posted November 25, 2021 Thought this was answered here new poster name. Exportar Excel e formatar células - Autodesk Community - AutoCAD Quote Link to comment Share on other sites More sharing options...
hosneyalaa Posted November 25, 2021 Share Posted November 25, 2021 3 hours ago, BIGAL said: Thought this was answered here new poster name. Exportar Excel e formatar células - Autodesk Community - AutoCAD https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/exportar-excel-e-formatar-celulas/td-p/10769819 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 25, 2021 Share Posted November 25, 2021 Thanks hosneyalaa i seen the copy paste not work correct, will double check in future that it worked for link. 1 Quote Link to comment Share on other sites More sharing options...
