NESTED BLOCK COPY
jim78b
i have to modify this lisp because not work 100% please.
It must work with all type of blocks even non uniform scaled. i try it but not work with non uniform scaled block.
I want even that i do a multiple selection
#NESTED BLOCKS COPY WITHOUT OPEN IT
(defun c:cx (/ *error* space ss nent br copy)
  (vl-load-com)
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument *acad*)))
  (defun *error* (msg)
    (and msg
         (/=(strcase msg) "FUNCTION CANCELLED")
    (vla-EndUndoMark *acdoc*)
  (vla-StartUndoMark *acdoc*)
  (setq space (if (= 1 (getvar 'cvport))
                (vla-get-PaperSpace *acdoc*)
                (vla-get-ModelSpace *acdoc*)
  (setq ss (ssadd))
  (while (and (setq nent (nentselp "\nSelect a nested block: "))
              (= 4 (length nent))
              (= "AcDbBlockReference" (vla-get-ObjectName (setq br (vlax-ename->vla-object (car (last nent))))))
              (apply '= (mapcar 'abs (list (vla-get-XScaleFactor br) (vla-get-YScaleFactor br) (vla-get-ZScaleFactor br))))
    (setq copy (vla-insertblock space (vlax-3d-point '(0 0 0)) (vla-get-Name br) 1.0 1.0 1.0 0.0))
    (vla-TransformBy copy (vlax-tmatrix (caddr nent)))
    (vla-Highlight copy :vlax-true)
    (ssadd (vlax-vla-object->ename copy) ss)
  (command "_.move" ss "")
  (*error* nil)
9 hours ago, Tharwat said:
Comment or delete this line.
I was about to say what Lee said... he beat me to it...
But it's an interesting challenge, I'll think about it.
