Guest JB_In_FLA Posted July 27, 2004 Posted July 27, 2004 I am finding myself lost at my new job without a few lisp routines that really made my life easier. All the routines did was allow you to select text and type in a prefix to add to it and the other allowed you to type a suffix to add to it. Does anyone have anything similar that they wouldn't mind posting for me? Any help is appreciated. Quote
David Bethel Posted July 27, 2004 Posted July 27, 2004 ;| HTH -David|; ;======================================================================= ; AddFix.Lsp Mar 14, 2000 ; Add Either Suffix Or Prefix To Selected Strings ;================== Start Program ====================================== (princ "\nCopyright (C) 2000, Fabricated Designs, Inc.") (princ "\nLoading AddFix v1.0 ") (setq af_ nil lsp_file "AddFix") ;================== Macros ============================================= (defun PDot ()(princ ".")) (PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++ (defun af_smd () (SetUndo) (setq olderr *error* *error* (lambda (e) (while (> (getvar "CMDACTIVE") 0) (command)) (and (/= e "quit / exit abort") (princ (strcat "\nError: *** " e " *** "))) (and (= (logand (getvar "UNDOCTL") 8) (command "_.UNDO" "_END" "_.U")) (af_rmd)) af_var '(("CMDECHO" . 0) ("MENUECHO" . 0) ("MENUCTL" . 0) ("MACROTRACE" . 0) ("OSMODE" . 0) ("SORTENTS" . 119) ("MODEMACRO" . ".") ("BLIPMODE" . 0) ("EXPERT" . 0) ("SNAPMODE" . 1) ("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS" . 0) ("FILEDIA" . 0) ("FILLMODE" . 0) ("SPLFRAME" . 0) ("UNITMODE" . 0) ("UCSICON" . 1) ("HIGHLIGHT" . 1) ("REGENMODE" . 1) ("COORDS" . 2) ("DRAGMODE" . 2) ("CECOLOR" . "BYLAYER") ("CELTYPE" . "BYLAYER"))) (foreach v af_var (and (getvar (car v)) (setq af_rst (cons (cons (car v) (getvar (car v))) af_rst)) (setvar (car v) (cdr v)))) (princ (strcat (getvar "PLATFORM") " Release " (ver) " - Add Text Prefix/Suffix ....\n")) (princ)) (PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++ (defun af_rmd () (setq *error* olderr) (foreach v af_rst (setvar (car v) (cdr v))) (command "_.UNDO" "_END") (prin1)) (PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++ (defun SetUndo () (and (zerop (getvar "UNDOCTL")) (command "_.UNDO" "_ALL")) (and (= (logand (getvar "UNDOCTL") 2) 2) (command "_.UNDO" "_CONTROL" "_ALL")) (and (= (logand (getvar "UNDOCTL") 8) (command "_.UNDO" "_END")) (command "_.UNDO" "_GROUP")) (PDot);************ Main Program *************************************** (defun af_ (/ olderr af_var af_rst st ns ss i en ed tv) (af_smd) (initget 1 "Prefix Suffix") (setq st (getkword "\nAdd Prefix/Suffix (P/S): ")) (setq ns (getstring t "\nNew String To Add: ")) (and (setq ss (ssget '((0 . "*TEXT")))) (setq i (sslength ss)) (while (not (minusp (setq i (1- i)))) (setq en (ssname ss i) ed (entget en) tv (cdr (assoc 1 ed)) ed (subst (cons 1 (if (= st "Suffix") (strcat tv ns) (strcat ns tv))) (assoc 1 ed) ed)) (entmod ed))) (af_rmd)) (PDot);************ Load Program *************************************** (defun C:AddFix () (af_)) (if af_ (princ "\nAddFix Loaded\n")) (prin1) ;|================== End Program ======================================= Quote
Guest JB_In_FLA Posted July 27, 2004 Posted July 27, 2004 Exactly what the doctor ordered! Thank you. - Joe Quote
Adesu Posted October 20, 2004 Posted October 20, 2004 Hi JB_In_FLA,you can try my code ; aft is stand for add front text ; Design by Ade Suharna ; 11 August 2004 ; program no. 67/09/2004 ; edit by Ade Suharna 10 September 2004 ; 06 October 2004 (defun c:aft (/ ent info1 opt ed) (while (setq ent (entget (car (entsel "\nCLICK TEXT FOR EDIT:"))) info1 (cdr (assoc 1 ent)) opt (getstring T (strcat "\nENTER NEW TEXT" "" ":")) ed (subst (cons 1 (strcat opt info1))(assoc 1 ent) ent)) (entmod ed) ) (princ) ) ; ta is stand for text add ; Design by Ade Suharna ; 10 September 2004 ; program no. 65/09/2004 ; edit by Ade Suharna 06/10/2004 (defun c:ta (/ ent info1 opt ed) (while (setq ent (entget (car (entsel "\nCLICK TEXT FOR EDIT:")))) (setq info1 (cdr (assoc 1 ent))) (setq opt (getstring (strcat "\nENTER NEW TEXT" "" ": "))) (setq ed (subst (cons 1 (strcat info1 " " opt))(assoc 1 ent) ent)) (entmod ed) ) (princ) ) Quote
Lee Mac Posted April 30, 2009 Posted April 30, 2009 This may help you in other ways: http://www.cadtutor.net/forum/showthread.php?t=35234 Quote
asos2000 Posted August 26, 2009 Posted August 26, 2009 thanx alanjt its great but not working with attribute Quote
alanjt Posted August 26, 2009 Posted August 26, 2009 asos2000 said: thanx alanjtits great but not working with attribute it's not supposed to. i had no interest in adding a prefix/suffix to attributes when i created it. Quote ;;; Allows user to add a Prefix and/or Suffix to selected;;; Text, Mtext and Multileaders. are you saying you would want to add a prefix/suffix to all attributes in a selected block, or just selected attributes within a block? if i have time today, when i get to work, i'll add it as an option. Quote
asos2000 Posted August 26, 2009 Posted August 26, 2009 Yes I would want to add a prefix/suffix to all attributes in selected blocks. Could be optional to deal with all attributes in selected blocks and selected attributes withen a block? Quote
alanjt Posted August 26, 2009 Posted August 26, 2009 asos2000 said: Yes I would want to add a prefix/suffix to all attributes in selected blocks. Could be optional to deal with all attributes in selected blocks and selected attributes withen a block? totally possible, i've got class in a few, but i'll look at it after i get to work. the code is free to the world, you are more than welcome to attempt to edit it yourself, just make note of it in the preface. Quote
funkkybebel Posted October 7, 2009 Posted October 7, 2009 So did you looked for attribute suffix and prefix ? Thank you for your help. Quote
alanjt Posted October 7, 2009 Posted October 7, 2009 funkkybebel said: So did you looked for attribute suffix and prefix ?Thank you for your help. I really haven't had the time. However, the code is there and you are more than welcome to give it a try. Quote
Cad64 Posted January 6, 2011 Posted January 6, 2011 alanjt said: here's what i do. i had to completely write a new one after switching to annotative text & beginning the use of mleaders. This is an old thread, but thank you for this Alan. You just saved me from several hours of very tedious work. Quote
xpr0 Posted November 8, 2021 Posted November 8, 2021 (edited) On 7/27/2004 at 3:21 PM, David Bethel said: ;| HTH -David|; ;======================================================================= ; AddFix.Lsp Mar 14, 2000 ; Add Either Suffix Or Prefix To Selected Strings ;================== Start Program ====================================== (princ "\nCopyright (C) 2000, Fabricated Designs, Inc.") (princ "\nLoading AddFix v1.0 ") (setq af_ nil lsp_file "AddFix") ;================== Macros ============================================= (defun PDot ()(princ ".")) (PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++ (defun af_smd () (SetUndo) (setq olderr *error* *error* (lambda (e) (while (> (getvar "CMDACTIVE") 0) (command)) (and (/= e "quit / exit abort") (princ (strcat "\nError: *** " e " *** "))) (and (= (logand (getvar "UNDOCTL") 8) (command "_.UNDO" "_END" "_.U")) (af_rmd)) af_var '(("CMDECHO" . 0) ("MENUECHO" . 0) ("MENUCTL" . 0) ("MACROTRACE" . 0) ("OSMODE" . 0) ("SORTENTS" . 119) ("MODEMACRO" . ".") ("BLIPMODE" . 0) ("EXPERT" . 0) ("SNAPMODE" . 1) ("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS" . 0) ("FILEDIA" . 0) ("FILLMODE" . 0) ("SPLFRAME" . 0) ("UNITMODE" . 0) ("UCSICON" . 1) ("HIGHLIGHT" . 1) ("REGENMODE" . 1) ("COORDS" . 2) ("DRAGMODE" . 2) ("CECOLOR" . "BYLAYER") ("CELTYPE" . "BYLAYER"))) (foreach v af_var (and (getvar (car v)) (setq af_rst (cons (cons (car v) (getvar (car v))) af_rst)) (setvar (car v) (cdr v)))) (princ (strcat (getvar "PLATFORM") " Release " (ver) " - Add Text Prefix/Suffix ....\n")) (princ)) (PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++ (defun af_rmd () (setq *error* olderr) (foreach v af_rst (setvar (car v) (cdr v))) (command "_.UNDO" "_END") (prin1)) (PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++ (defun SetUndo () (and (zerop (getvar "UNDOCTL")) (command "_.UNDO" "_ALL")) (and (= (logand (getvar "UNDOCTL") 2) 2) (command "_.UNDO" "_CONTROL" "_ALL")) (and (= (logand (getvar "UNDOCTL") 8) (command "_.UNDO" "_END")) (command "_.UNDO" "_GROUP")) (PDot);************ Main Program *************************************** (defun af_ (/ olderr af_var af_rst st ns ss i en ed tv) (af_smd) (initget 1 "Prefix Suffix") (setq st (getkword "\nAdd Prefix/Suffix (P/S): ")) (setq ns (getstring t "\nNew String To Add: ")) (and (setq ss (ssget '((0 . "*TEXT")))) (setq i (sslength ss)) (while (not (minusp (setq i (1- i)))) (setq en (ssname ss i) ed (entget en) tv (cdr (assoc 1 ed)) ed (subst (cons 1 (if (= st "Suffix") (strcat tv ns) (strcat ns tv))) (assoc 1 ed) ed)) (entmod ed))) (af_rmd)) (PDot);************ Load Program *************************************** (defun C:AddFix () (af_)) (if af_ (princ "\nAddFix Loaded\n")) (prin1) ;|================== End Program ======================================= Expand i m trying to load this lisp but its throwing up this error in autocad 2017 Quote Command: AP APPLOAD Addfix.lsp successfully loaded. Command: Copyright (C) 2000, Fabricated Designs, Inc. Loading AddFix v1.0 .; error: malformed list on input Edited November 8, 2021 by xpr0 Quote
marko_ribar Posted November 8, 2021 Posted November 8, 2021 (edited) I haven't checked it deeply, but I believe here is the bug : (and (= (logand (getvar "UNDOCTL") (command "_.UNDO" "_END" "_.U")) (and (= (logand (getvar "UNDOCTL") (command "_.UNDO" "_END")) Probably bug occured when site changed style - this is typical consequence - there are many examples where was missing due to the fact that represent similey with black glasses so it was erased... Edited November 8, 2021 by marko_ribar replace all smileys with 8) to see correctly... can't find disable smileys option... Quote
mhupp Posted November 8, 2021 Posted November 8, 2021 (edited) Here one I came up with. variable is saved to registry so it will persist between drawings. ;;----------------------------------------------------------------------------;; ;; ADD TEXT PREFIX OR SUFFIX TO EXISTING TEXT (defun C:ADDTXT (/ rep str *str ss txt sn vl e) (vl-load-com) (initget "Prefix Suffix") (setq rep (cond ((getkword "\nWhere to add Text [Prefix/Suffix]<Suffix>:")) ( "Suffix") ) ) (or (setq *str (getenv "Insert-Text")) (setq *str "Here")) (if (= "" (setq str (getstring (strcat "\nEnter " rep " Text \"" *str "\": ")))) (setq str *str) ) (setenv "Insert-Text" str) (setq ss (ssget "_:L" '((0 . "*TEXT")))) (foreach txt (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq vl (vlax-ename->vla-object txt)) (setq e (entget txt)) (cond ((= rep "Prefix") (vla-put-textstring vl (strcat str (cdr (assoc 1 e)))) ) ((= rep "Suffix") (vla-put-textstring vl (strcat (cdr (assoc 1 e)) str)) ) ) ) (princ) ) Edited November 8, 2021 by mhupp added vl-load-com incase you don't have it loaded already. Quote
smitaranjan Posted January 8 Posted January 8 On 11/8/2021 at 6:39 PM, mhupp said: Here one I came up with. variable is saved to registry so it will persist between drawings. ;;----------------------------------------------------------------------------;; ;; ADD TEXT PREFIX OR SUFFIX TO EXISTING TEXT (defun C:ADDTXT (/ rep str *str ss txt sn vl e) (vl-load-com) (initget "Prefix Suffix") (setq rep (cond ((getkword "\nWhere to add Text [Prefix/Suffix]<Suffix>:")) ( "Suffix") ) ) (or (setq *str (getenv "Insert-Text")) (setq *str "Here")) (if (= "" (setq str (getstring (strcat "\nEnter " rep " Text \"" *str "\": ")))) (setq str *str) ) (setenv "Insert-Text" str) (setq ss (ssget "_:L" '((0 . "*TEXT")))) (foreach txt (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (setq vl (vlax-ename->vla-object txt)) (setq e (entget txt)) (cond ((= rep "Prefix") (vla-put-textstring vl (strcat str (cdr (assoc 1 e)))) ) ((= rep "Suffix") (vla-put-textstring vl (strcat (cdr (assoc 1 e)) str)) ) ) ) (princ) ) Expand how to include block attributes text too Quote
asos2000 Posted January 8 Posted January 8 On 1/8/2025 at 10:57 AM, smitaranjan said: how to include block attributes text too 1 Quote
