Lisp to add a prefix or suffix to selected text
Guest JB_In_FLA
I am finding myself lost at my new job without a few lisp routines that really made my life easier. All the routines did was allow you to select text and type in a prefix to add to it and the other allowed you to type a suffix to add to it. Does anyone have anything similar that they wouldn't mind posting for me? Any help is appreciated.
;| HTH -David|;
;    AddFix.Lsp                                    Mar 14, 2000
;    Add Either Suffix Or Prefix To Selected Strings
;================== Start Program ======================================
(princ "\nCopyright (C) 2000, Fabricated Designs, Inc.")
(princ "\nLoading AddFix v1.0 ")
(setq af_ nil lsp_file "AddFix")
;================== Macros =============================================
(defun PDot ()(princ "."))
(PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++
(defun af_smd ()
(SetUndo)
(setq olderr *error*
     *error* (lambda (e)
               (while (> (getvar "CMDACTIVE") 0)
                      (command))
               (and (/= e "quit / exit abort")
                    (princ (strcat "\nError: *** " e " *** ")))
               (and (= (logand (getvar "UNDOCTL")  8)
                    (command "_.UNDO" "_END" "_.U"))
               (af_rmd))
      af_var '(("CMDECHO"   . 0) ("MENUECHO"   . 0)
               ("MENUCTL"   . 0) ("MACROTRACE" . 0)
               ("OSMODE"    . 0) ("SORTENTS"   . 119)
               ("MODEMACRO" . ".")
               ("BLIPMODE"  . 0) ("EXPERT"     . 0)
               ("SNAPMODE"  . 1)
               ("ORTHOMODE" . 1) ("GRIDMODE"   . 0)
               ("ELEVATION" . 0) ("THICKNESS"  . 0)
               ("FILEDIA"   . 0) ("FILLMODE"   . 0)
               ("SPLFRAME"  . 0) ("UNITMODE"   . 0)
               ("UCSICON"    . 1)
               ("HIGHLIGHT" . 1) ("REGENMODE"  . 1)
               ("COORDS"    . 2) ("DRAGMODE"   . 2)
               ("CECOLOR"   . "BYLAYER")
               ("CELTYPE"   . "BYLAYER")))
(foreach v af_var
  (and (getvar (car v))
       (setq af_rst (cons (cons (car v) (getvar (car v))) af_rst))
       (setvar (car v) (cdr v))))
(princ (strcat (getvar "PLATFORM") " Release " (ver)
       " -  Add Text Prefix/Suffix ....\n"))
(princ))
(PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++
(defun af_rmd ()
 (setq *error* olderr)
 (foreach v af_rst (setvar (car v) (cdr v)))
 (command "_.UNDO" "_END")
 (prin1))
(PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++
(defun SetUndo ()
(and (zerop (getvar "UNDOCTL"))
     (command "_.UNDO" "_ALL"))
(and (= (logand (getvar "UNDOCTL") 2) 2)
     (command "_.UNDO" "_CONTROL" "_ALL"))
     (command "_.UNDO" "_END"))
(command "_.UNDO" "_GROUP"))
(PDot);************ Main Program ***************************************
(defun af_ (/ olderr af_var af_rst st ns ss i en ed tv)
 (af_smd)
 (initget 1 "Prefix Suffix")
 (setq st (getkword "\nAdd Prefix/Suffix (P/S):   "))
 (setq ns (getstring t "\nNew String To Add:   "))
 (and (setq ss (ssget '((0 . "*TEXT"))))
      (setq i (sslength ss))
      (while (not (minusp (setq i (1- i))))
             (setq en (ssname ss i)
                   ed (entget en)
                   tv (cdr (assoc 1 ed))
                   ed (subst
                        (cons 1 (if (= st "Suffix")
                                    (strcat tv ns)
                                    (strcat ns tv)))
                        (assoc 1 ed) ed))
              (entmod ed)))
 (af_rmd))
(PDot);************ Load Program ***************************************
(defun C:AddFix () (af_))
(if af_ (princ "\nAddFix Loaded\n"))
(prin1)
;|================== End Program =======================================
Guest JB_In_FLA
Exactly what the doctor ordered! Thank you.
- Joe
  • 2 months later...
Hi JB_In_FLA,you can try my code
; aft is stand for add front text
; Design by Ade Suharna
; 11 August 2004
; program no. 67/09/2004
; edit by Ade Suharna 10 September 2004
; 06 October 2004
(defun c:aft (/ ent info1 opt ed)
(while
(setq ent (entget (car (entsel "\nCLICK TEXT FOR EDIT:")))
info1 (cdr (assoc 1 ent))
opt
(getstring T
(strcat "\nENTER NEW TEXT" "" ":"))
ed (subst (cons 1 (strcat opt info1))(assoc 1 ent) ent))
(entmod ed)
; ta is stand for text add
; 10 September 2004
; program no. 65/09/2004
; edit by Ade Suharna 06/10/2004
(defun c:ta (/ ent info1 opt ed)
(while
(setq ent (entget (car (entsel "\nCLICK TEXT FOR EDIT:"))))
(setq info1 (cdr (assoc 1 ent)))
(setq opt (getstring (strcat "\nENTER NEW TEXT" "" ": ")))
(setq ed (subst (cons 1 (strcat info1 " " opt))(assoc 1 ent) ent))
(entmod ed)
  • 4 years later...
  • 3 months later...
thanx alanjt
its great but not working with attribute
  asos2000 said:
thanx alanjt
it's not supposed to. i had no interest in adding a prefix/suffix to attributes when i created it.
  Quote
;;; Allows user to add a Prefix and/or Suffix to selected
;;; Text, Mtext and Multileaders.
are you saying you would want to add a prefix/suffix to all attributes in a selected block, or just selected attributes within a block? if i have time today, when i get to work, i'll add it as an option.
Yes I would want to add a prefix/suffix to all attributes in selected blocks.
Could be optional to deal with all attributes in selected blocks and selected attributes withen a block?
totally possible, i've got class in a few, but i'll look at it after i get to work.
the code is free to the world, you are more than welcome to attempt to edit it yourself, just make note of it in the preface.
  • 1 month later...
So did you looked for attribute suffix and prefix ?
Thank you for your help.
I really haven't had the time. However, the code is there and you are more than welcome to give it a try.
  • 1 year later...
  alanjt said:
here's what i do. i had to completely write a new one after switching to annotative text & beginning the use of mleaders.
This is an old thread, but thank you for this Alan. You just saved me from several hours of very tedious work. :thumbsup:
  • 10 years later...
  On 7/27/2004 at 3:21 PM, David Bethel said:
;| HTH -David|;
(defun af_smd ()
(SetUndo)
     *error* (lambda (e)
                      (command))
               (af_rmd))
               ("MODEMACRO" . ".")
               ("SNAPMODE"  . 1)
               ("UCSICON"    . 1)
(foreach v af_var
(princ))
(defun af_rmd ()
 (prin1))
(defun SetUndo ()
 (af_smd)
                   ed (entget en)
                   ed (subst
                                    (strcat tv ns)
                                    (strcat ns tv)))
                        (assoc 1 ed) ed))
              (entmod ed)))
 (af_rmd))
(prin1)
Expand
 i m trying to load this lisp but its throwing up this error in autocad 2017
  Quote
Command: AP
APPLOAD Addfix.lsp successfully loaded.
Command:
Loading AddFix v1.0 .; error: malformed list on input
Expand
Edited by xpr0
I haven't checked it deeply, but I believe here is the bug :
(and (= (logand (getvar "UNDOCTL") 8) 8) (command "_.UNDO" "_END" "_.U"))
(and (= (logand (getvar "UNDOCTL") 8) 8) (command "_.UNDO" "_END"))
Probably bug occured when site changed style - this is typical consequence - there are many examples where 8) was missing due to the fact that 8) represent similey with black glasses so it was erased...
Edited by marko_ribar
replace all smileys with 8) to see correctly... can't find disable smileys option...
Here one I came up with. variable is saved to registry so it will persist between drawings.
;; ADD TEXT PREFIX OR SUFFIX TO EXISTING TEXT
(defun C:ADDTXT (/ rep str *str ss txt sn vl e)
  (vl-load-com)
  (initget "Prefix Suffix")
  (setq rep
    (cond
      ((getkword "\nWhere to add Text [Prefix/Suffix]<Suffix>:")) ( "Suffix")
  (or (setq *str (getenv "Insert-Text")) (setq *str "Here"))
  (if (= "" (setq str (getstring (strcat "\nEnter " rep " Text \"" *str "\": "))))
    (setq str *str)
  (setenv "Insert-Text" str)
  (setq ss (ssget "_:L" '((0 . "*TEXT"))))
  (foreach txt (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))
    (setq vl (vlax-ename->vla-object txt))
    (setq e (entget txt))
    (cond
      ((= rep "Prefix")
          (vla-put-textstring vl (strcat str (cdr (assoc 1 e))))
      ((= rep "Suffix")
          (vla-put-textstring vl (strcat (cdr (assoc 1 e)) str))
Edited by mhupp
added vl-load-com incase you don't have it loaded already.
  • 3 years later...
  (vl-load-com)
  (setq rep
    (cond
    (setq str *str)
    (cond
      ((= rep "Prefix")
      ((= rep "Suffix")
Expand
how to include block attributes text too
Expand
  • Thanks 1
