Create list of variables from toggle-box
Hi all, I have variables here from a toggle dialog box that contain either the value 0 or 1.
How can I create a list from them?
 (setq vision_pair1 (get_tile "t1")
       vision_pair2 (get_tile "t2")
       vision_pair3 (get_tile "t3")
       vision_pair4 (get_tile "t4")
       vision_pair5 (get_tile "t5")
       vision_pair6 (get_tile "t6")
       vision_pair7 (get_tile "t7")
       vision_pair8 (get_tile "t8")
       vision_pair9 (get_tile "t9")
       vision_pair10 (get_tile "t10")
For example, I want to show all variables in an acet-ui-message (or alert-box) that contain the value 1.
You dont have to do it that way can just loop trough the toggle buttons as you know they are t+number. Simplest way is look at these programs, Multi Radio Buttons, Multi Getvals and Multi toggles are in the download section here at cadtutor. Yes the Multi Toggles makes a single  list (0 1 0 1 1 1 0 1 0 1)
The bit you want
(defun mkv_lst ( / )
(setq v_lst '())
(setq x 1)
(repeat (- (length ahbutlst) 1)
(setq val (strcat "Tb" (rtos x 2 0)))
(setq v_lst (cons (get_tile val) v_lst))
(setq x (+ x 1))
(setq y 0)
    (setq keynum (strcat "Tb" (rtos (setq y (+ Y 1)) 2 0)))
    (set_tile keynum "0")
    (mode_tile keynum 3)
(action_tile "accept" "(mkv_lst)(done_dialog)")
I modified this for my needs. Thanks for the code!
