Property sets for styles in Acad Architecture
Hi there,
I've seen plenty of great VBA code in this forum so far that interrogates and retrieves attributes for AutoCad blocks. That works great but a division within my company uses AutoCad architecture... and therefore uses MultiView blocks for labelling up rooms etc instead of AutoCad blocks.
We can extract geospace parameters from mvBlocks like room name or department (using the code below), but we now need to extract property set values attached to the style - but all attempts return no recordset for the style - We're looking for some of the standard values like length, area etc...
Can anyone help?
Many thanks in advance,
Mick
Code:
Public Sub TestCode()
Dim SchedApp As New AecScheduleApplication
Dim Ent As AcadEntity
Dim Pt As Variant
Dim Geo As AecGeo
Dim Anchor As AecAnchorExtendedTagToEnt
Dim RefObj As AcadEntity
Dim Propset As AecSchedulePropertySet
Dim cProps As AecScheduleProperties
Dim oProp As AecScheduleProperty
ThisDrawing.Utility.GetEntity Ent, Pt, "Select Block Ref"
If TypeOf Ent Is AecMVBlockRef Then
If TypeOf Ent Is AecGeo Then
Set Geo = Ent
Set Anchor = Geo.GetAnchor
End If
Set RefObj = Anchor.Reference
Set cPropSets = SchedApp.PropertySets(RefObj)
'can the above line work with ent.style in the brackets?
'It only returns 0 property set count
If cPropSets.count > 0 Then
Set Propset = cPropSets.Item(0)
Set cProps = Propset.Properties
For Each oProp In cProps
MsgBox oProp.Name & " = " & oProp.Value
Next
Else
MsgBox "There are no properties for this object"
End If
End If
End Sub
