I have a problem.
when Im working on the viewport and I creates a new dimension, the scale of the dimension I made is not like it should be.
If I'm creating new one in the model space and then go to the layout it show the dim correctly.
my solution for now is creating the dim in the model then go to the viewport and create new one (which look teribble) and do match between the dimensions.
note: Im not working with annotative dimentions
I hope someone knows how can I fix it
TNX for the replies!
The value is correct,
see the file I add,
the upper dim I create in the viewport.
the lower one I create in the model space
Edited by tehila
Sorry I misunderstood the issue.
You'll need to set up the dimension style and sizes to look appropriate in the space you want.
If you are using nonassociative dimensions, and dimensioning in Paperspace, as I do.
Go into MODIFY for your Dimstyle, and check on your FIT tab.
I believe you want it as shown in the screenshot.
Specifically the Scale for dimension features, select use overall scale of 1.
  • Agree 1
THATS WORKS!!
TNX!!!!
You're welcome, always happy to be of assistance!      :beer:
