<Update:>
The issue I encountered was a drawing converted from VISIO to Autocad.
If I convert the fonts to ARIAL beforehand, I can use STRIPMTEXT
if not I have to use one of the methods below.
I have several drawings filled with MText objects.
If I select them all and attempt to change via the Properties dialog
a new height is then displayed but the text height does not change.
If I double click on one of the objects the Text Formatting bar appears
and a different text height is shown there.
I thought that Lee's STRIPMTEXT would resolve this but running it
leaves me with the same issue afterwards.
This may be the wrong forum but if anyone knows of a routing to resolve this
I would appreciate being pointed to it please..
I have hundreds of text objects to change.
Please advise.
(feel free to move this thread if it shouldn't be here)
Edited by ILoveMadoka
Just to show that I am using Stripmtext
After I ran that routine, I tried changing the objects to a different style then changing them back
but I still have the discrepancy between the Properties Dialog and the Text Formatting bar.
From what i remember about AutoCAD your standard style text height is set to 0.0938 and is overwriting anything you change it to. if you change that value to 0 it defualts to user defined heights. this is why it works when you change it to another style it has a value of 0 probably. BriscsCAD it will default to the style text height when creating any text but allows you to change it to what ever you want.
--Edit--
same applys to dimsyle
Edited by mhupp
I forget how to make it do this, but strip Mtext usually works, I don' think SMT is one of Lees, happy to be corrected if I am wrong, but he does have this:  http://lee-mac.com/unformatstring.html which removes mtext formatting - can't say I have ever used it for this though, but it could be something to try
If all the mtext has a default height then using Vla-put-height will work or entmod code 40 which is height.
aaa nnn ccc
If the text has  a height over ride it will have something like this ;   TextString = "aaa  {\\H2x;nnn} ccc", Height by 2, so removing the formatting should fix then change height.
It was really strange, if I ran the stripmtext on  a single string it worked
if I tried larger selections sets it did not.
I saw the formatting for the height was there but didn't know how to remove it for all the text that I had to change.
I wish I had seen Lee's Unformat String.
I ended up having to destroy the drawing then rebuild it from scratch for the most part.
It's taken me 2 days to get it "correct"
sigh..
appreciate all the feedback..
I'll know next time.
For another time, instead of rebuilding the drawing if it all fails, you could explode the mtext to basic text and then txt2mtxt to recombine it, might be quicker and should also remove all the mtext formatting.. but will still take time
Has anyone created a routine using Lee's Unformat so that I could select and process all mtext?
I do not understand that code enough to know how to use it.
Seems straightforward but it's out of my league..
that is what I ended up doing.
It was several drawings full of text so it was two days of fun...
correct.
It's here (STRIPMTEXT)
Can Lee's UNFORMATSTRING be incorporated into a routine with a selection set?
I don't understand what it does to even attempt something.
This is the code from Lee's site
;;-------------------=={ UnFormat String }==------------------;;
;;  Returns a string with all MText formatting codes removed. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  str - String to Process                                   ;;
;;  mtx - MText Flag (T if string is for use in MText)        ;;
;;  Returns:  String with formatting codes removed            ;;
(defun LM:UnFormat ( str mtx / _replace rx )
    (defun _replace ( new old str )
        (vlax-put-property rx 'pattern old)
        (vlax-invoke rx 'replace str new)
    (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
            (setq str
                (vl-catch-all-apply
                    (function
                        (lambda ( )
                            (vlax-put-property rx 'global     actrue)
                            (vlax-put-property rx 'multiline  actrue)
                            (vlax-put-property rx 'ignorecase acfalse)
                            (foreach pair
                                    ("\032"    . "\\\\\\\\")
                                    (" "       . "\\\\P|\\n|\\t")
                                    ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                                    ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                                    ("$1$2"    . "\\\\(\\\\S)|[\\\\](})|}")
                                    ("$1"      . "[\\\\]({)|{")
                                (setq str (_replace (car pair) (cdr pair) str))
                            (if mtx
                                (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
                                (_replace "\\"   "\032" str)
            (vlax-release-object rx)
            (if (null (vl-catch-all-error-p str))
                str
(vl-load-com)
Have to feed it a string. then the mtx is if its just oputs txt or input back into mtext.
This should strip all mtext of their formatting.
(defun C:UnFormat-MTEXT (/ ss txt a ent entity)
  (setq SS (ssget "_X" '((0 . "MTEXT"))))
  (foreach ent (mapcar 'cadr (ssnamex SS))
    (setq txt (LM:gettextstring ent))
    (setq txt (LM:UnFormat txt t))
    (setq entity (entget ent))
    (entmod (subst (cons 1 txt) (assoc 1 entity) entity))
(defun LM:gettextstring (ent / enx itm str typ)
  (setq enx (entget ent)
        typ (cdr (assoc 0 enx))
  (cond
    ((wcmatch typ "TEXT,*DIMENSION")
              (cdr (assoc 1 (reverse enx)))
    ((and (= "MULTILEADER" typ)
          (= 5 (cdr (assoc 172 enx)))
      (cdr (assoc 304 enx))
    ((wcmatch typ "ATTRIB,MTEXT")
              (setq str (cdr (assoc 1 (reverse enx))))
      (while (setq itm (assoc 3 enx))
        (setq str (strcat (cdr itm) str)
              enx (cdr (member itm enx))
      str
;;  Arguments:                                                ;;
(defun LM:UnFormat (str mtx / _replace rx)
  (vl-load-com)
  (defun _replace (new old str)
      (setq str
            (vl-catch-all-apply
              (function
                (lambda ()
                  (foreach pair
                       ( "\032" . "\\\\\\\\")
                       ( " " . "\\\\P|\\n|\\t")
                       ( "$1" . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                       ( "$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                       ( "$1$2" . "\\\\(\\\\S)|[\\\\](})|}")
                       ( "$1" . "[\\\\]({)|{")
                  (if mtx
        str
Edited by mhupp
That works PERFECTLY!!  <Awesome! THANK YOU!!>
I wanted to make one change but I cannot incorporate it correctly..
I want the option to run the routine on ALL or on a Selection Set.
How do I add/incorporate this?
(initget "All Select")
(setq select (getkword "\nSelect text to change: <A>ll or <S>elect? "))
   (if select (cond
   ((= select "All")(setq SS (ssget "_X" '((0 . "MTEXT")))))
   ((= select "Select")(setq SS (ssget))) ))
The following DOES NOT WORK for me. I get Invalid Option Keyword.
I'd like to know what I did wrong or was missing since I'm trying to learn..
   (if select (cond
  (cond
      str
;;  Arguments:                                                ;;
  (vl-load-com)
      (setq str
            (vl-catch-all-apply
              (function
                (lambda ()
                  (foreach pair
                  (if mtx
        str
Getkwords must match initget try:
(getkword "\nSelect text to change: All or Select? ")
A, S, All, Select, all & select would all be valid responses as well as picking with the mouse.
Try this mod...
(defun C:UnFormat-MTEXT ( / select ss txt entity )
  (setq select (getkword "\nSelect text to change [All/Select] <Select> : "))
  (if select
    (cond
      ( (= select "All") (setq SS (ssget "_X" '((0 . "MTEXT")))) )
      ( (= select "Select") (setq SS (ssget "_:L")) )
  (foreach ent (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex SS)))
    (entupd (cdr (assoc -1 (entmod (subst (cons 1 txt) (assoc 1 entity) entity))))) ;;; I am not sure about DXF 1 Group Code for MTEXT...
Edited by marko_ribar
  • Like 2
Both of those worked perfectly..
Thank you.
This sets the default option.
(setq select
  (cond
    ((getkword "\nSelect text to change [All/Select] <Select> : ")) ("Select")
(cond
  ((= select "Select") (setq SS (ssget "_:L" '((0 . "MTEXT"))))) ; Prob should limit the selection to mtext. don't know if the entmod would error if other things where picked.
  ((= select "All") (setq SS (ssget "_X" '((0 . "MTEXT")))))
Edited by mhupp
Thank you.
Thanks to everyone!
This is a tremendous help!
  • 3 weeks later...
Again, thank you everyone.
I ran across this after the fact and I love it... (Thanks once more to LeeMac!!)
I wanted to post this for anyone who may need it in the future.
(defun c:unformat ( / *error* enx idx rgx sel str )
;;;https://www.theswamp.org/index.php?topic=52929.msg577561
;;;LeeMac
    (defun *error* ( msg )
        (if (and (= 'vla-object (type rgx)) (not (vlax-object-released-p rgx)))
            (vlax-release-object rgx)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
    (cond
        (   (or (vl-catch-all-error-p (setq rgx (vl-catch-all-apply 'vlax-get-or-create-object '("vbscript.regexp"))))
                (null rgx)
            (princ "\nUnable to interface with RegExp object.")
        (   (setq sel (ssget "_:L" '((0 . "MTEXT"))))
            (repeat (setq idx (sslength sel))
                (setq enx (entget (ssname sel (setq idx (1- idx))))
                      str (assoc 1 enx)
                (entmod (subst (cons 1 (LM:quickunformat rgx (cdr str))) str enx))
    (*error* nil) (princ)
;; Quick Unformat  -  Lee Mac
;; rgx - [vla] Regular Expressions (RegExp) Object
;; str - [str] String to process
(defun LM:quickunformat ( rgx str )
    (if
        (null
                (setq str
                    (vl-catch-all-apply
                       '(lambda nil
                            (vlax-put-property rgx 'global     actrue)
                            (vlax-put-property rgx 'multiline  actrue)
                            (vlax-put-property rgx 'ignorecase acfalse)
                            (foreach pair
                                    ("$1"       . "\\\\(\\\\[ACcFfHKkLlOopQTW])|\\\\[ACcFfHKkLlOopQTW][^\\\\;]*;|\\\\[ACcFfKkHLlOopQTW]")
                                    ("\\$1$2$3" . "(\\\\[ACcFfHKkLlOoPpQSTW])|({)|(})")
                                    ("\\\\"     . "\032")
                                (vlax-put-property rgx 'pattern (cdr pair))
                                (setq str (vlax-invoke rgx 'replace str (car pair)))
        str
(vl-load-com) (princ)
