Have the bubble on it's own layer
Bob_W
I have attached a Lisp program that I got many years ago from Cadalyst Hot tip Harry’s.
https://cadtips.cadalyst.com/
I have no way to contact the original author, Ray Burnstad.
I would like to have the bubble be put on it’s own layer. I have looked to see how to do it but my Lisp knowledge would not fill the subject line.
Since this was a free to download and use I don’t know if there would be a problem with modifying it. If this is not allowed I understand.
Thanks
Bob_W
BUB.lsp
Looks like it puts the bubble on the current layer. either change your current layer before running the command or
Change the following in the lisp.  update "layername" to the layer you want
; Main function
(defun C:BUB (/ SS TXTLIM LL UR MP NX NY P1 olay)
  (setq olay (getvar 'clayer)) ;saves current layer before changing it in next line.
  (setvar 'clayer "layername") ;layer name you want the bubble to be on.
end of main function
  (setvar 'clayer olay) ;sets current layer back to before the lisp
There is also an function missing in this lisp that causes it not to run successfully.
; ----- Error around expression -----
; (BUB_NOTE_GET_POINT)
Make sure you have the all of the lisp loaded.
https://cadtips.cadalyst.com/notestext/bubble-note
Edited by mhupp
First - Thank You
FYI, the link you showed is actually a different lisp by the same author. The original bub.lsp seems to be gone. The one I originally attached runs OK
Using the code you provided I can now get the bubble on it's own layer. I had to make some changes, at first I could not make it work. Most likely my fault.
It does not change back to the current layer, again I'm probably putting it the wrong location or lost a parentheses or ???
Can you show where it goes, original end of main function below;
    (setvar "SNAPMODE" SM)
    (setvar "CMDECHO" 1)
    (setq *ERROR* OE)
; Draws bubble border polyline
2 hours ago, Bob_W said:
First - Thank You
    (setq *ERROR* OE)
Add this line and you don't have to worry about the current layer changing:
  • Agree 1
Thank You ronjonp
That makes it work as I wanted.
I made a 'bubble' layer to set color and lineweight for the 'bubble"
I'm sure that can be done in the lisp but a layer works fine.
Bob_W
I have a library routine chklay that just does that checks does layer exist, if not make it (chklay "Bubble" 2 "DASHED") .
Or can do (command "Layer" "M" "Bubble" "c" 2 "Bubble" "lt" "Dashed" "Bubble" "") as make layer will continue if it exists.
Edited by BIGAL
I am not a member of the Lisperatti, so out of my depth...
but I use and love LeeMacs awesome LAYER DIRECTOR lisp
Thanks @LEEMAC ! :beer:
which would be able to do this for you.
When in doubt?   Check LeeMac out!  :thumbsup:
On 10/28/2021 at 3:29 PM, Bob_W said:
Thank You ronjonp
Bob_W
Sure it can be done.  It was stated in a way like that by @BIGAL in the post above yours.
You can also check the '-layer' (with the - in front of it) command to see what options you have to create a layer with the style you want.
Something like below (not tested!) would create a layer named 'LAYERNAME' that is megenta, not visible on plot and has a dashed linetype.
(command "-Layer" "make" "LAYERNAME" "color" "magenta" "" "plot" "n" "lt" "Dashed" "")
