Ben Hardy Posted October 24, 2021 Posted October 24, 2021 Hi there, I'm new to AutoCad 22, so apologies in advance. When I open my Drawing Units I cannot add Direction. I can specify Length Angle etc.. but won't allow me to select OK, Canel, Direction etc. just the 'error' beep like in this video. Thanks for your help! Ben 326968017_UNITSBUG.mp4 Quote
BIGAL Posted October 25, 2021 Posted October 25, 2021 A manual override is, Angdir sets clockwise etc 0 or 1, Angbase for the direction, 0 90 180 270 etc no idea why not working. 1 Quote
SLW210 Posted October 25, 2021 Posted October 25, 2021 Or -UNITS will bypass the dialog box. My dialog box works fine, though. The shortcuts by BIGAL, can also be set using ACADDOC.LSP, or you can run a script to set drawings up the way you prefer, Sysvars saved per drawing can be set in a drawing template as well. Not sure why the dialog box doesn't work, mine works just fine. Is it not working in all drawings? Quote
