Martin74 Posted October 22, 2021 Share Posted October 22, 2021 Hello. This LISP selects all dimension and changes to layer "_DIM_" (if (ssget "_X" '((0 . "DIMENSION"))) (command "._change" (ssget "_X" '((0 . "DIMENSION"))) "" "P" "LA" "_DIM_" "") );if I'm looking for similar to select block(s) by name and change layer. Appreciate any advice. Quote Link to comment Share on other sites More sharing options...
zwonko Posted October 24, 2021 Share Posted October 24, 2021 (edited) For blocks selection (if (setq ss (ssget '((0 . "INSERT") (2 . "bik_BlkOpPret,bik_BlkOpPretU,bik_BlkOpPretW")))) Where bik_Blk* are names od blocks. If You need blocks im all drawing use ssget _X as on Your post. More samples here. http://www.lee-mac.com/ssget.html Edited October 24, 2021 by zwonko Quote Link to comment Share on other sites More sharing options...
mhupp Posted October 24, 2021 Share Posted October 24, 2021 If you end up using the ssget "_X" option its a good idea to throw on the old 410 as well. (if (setq ss (ssget '((0 . "INSERT") (2 . "block1,block2,block3") (410 . "Model")))) 410 = tab they are located on. can't change properties of a block on a different tab with (command "._change" you would have to use visual lisp for that. Quote Link to comment Share on other sites More sharing options...
