Lisp for drawing line and add text on cross section
Hello, I need some help with drawing lines , I try to explain what i need.
I have a lot of cross sections to create, and the dwg files provided to me  as 2d not 3d, so I have no elevation data. l'm using Progecad 2021, and it has AutoSEZ addon built it, the module is creating the cross sections, but I need to edit them individually and edit add missing elements.
In attached file you see , I have 3 areas to fill , the 2 ditches on sides, and the main road profile in center.
Now I'm following this steps:
- Make a (red) centerline for each ditch , then copy paste a group made of a polyline and text, that snaps to the bottom vertex of centerline , then adjust the polyline to snap to edges of ditch, and delete the centerline
- And the next step is to copy a group made of a polyline and text and snap to the center line to get then road profile, then extend or trim the line to the edges of the road
Now, sometimes id a ditch on both sides, sometime just one side, sometimes no ditch just the road profile.
I have very little experience writing Lips, I did edited some free ones to fit my needs, and I wonder if there is possible to make 1 lisp to automate this steps I make, or 2 lisp files: one for center profile one for the ditch part ?
Need to mention must be simple Lisp not Visual lisp , as Progecad wont be able to run it.
If someone can guide me how to create a Lisp that make a line or polyline , by  selecting the 2 top vertex of ditch side , then calculate where is the centerline, and draw at a degree (set in lisp, with overwrite possibility ) from 1st  to centerline then back on same degree to second vertex , and add a text.
And for second lisp , I guess the steps would be, pick the road center top vertex , pick the road sides (lines) , and at a certain degree (set in lisp but possible overwrite it on command) draw 2 lines on left and right + add text above.
Let me know if is possible and if it is some hints, would be great
Thanks a lot
Romeo
The drains are very easy to draw, you get 2 points, then work out a 3rd point and draw 2 lines. (command "LINE" pt1 pt3 pt2 "")
(setq pt1 (getpoint "\nPick point 1 "))
(setq pt2 (getpoint "\nPick point 2 "))
(setq x1 (car pt1) y1 (cadr pt1))
(setq x2 (car pt2) y2 (cadr pt2))
(setq X (/ (+ x1 x2) 2.0)))
(setq Y (- y depth))
(seqt pt3 (list X Y))
You can apply the same type of idea to the centre line.
Hi BIGAL, and thanks for the quick reply.
It was very helpful, gave me the direction to move on, and I made this solution, I know there are room for improvements.
Here is what I did:
defun C:SNT ( / pt1 pt2 pt3 midist distlung) ; Im not sure if all this "variables" need to be passes as arguments
(setq pt1 (getpoint "\nSelect first point: "))
(setq pt2 (getpoint "\nSelect second point: "))
(setq midist (/ (distance pt1 pt2) 2.0)) ; calculates half of distance
(setq distlung (/ (* midist 2.0) 1.7320508075688772)) ; calculates corect lenght for 30 degree
(setq pt3 (polar pt1 5.7595865316 distlung)) ; angle as radians
(command "Line" pt1 pt3 pt2 "")
The  above LISP draws exactly what I need, and saves me some extra clicks for each cross section.
I also want to Insert some text just after lines are created, but adding a second Command for the text , like (command "Text" "x,y" 0.25 0 "Sant") is not working.
I would like to place it just where the middle point is,  like in example attached.
I would like the text to be set in Lisp,  like rotation, size, etc,  so the software is not asking anything , just place it.
Any suggestion how to achieve this?
Thanks
Gal Romeo
Expand
Why don't you try:
(setq pt4 (list (/ (+ (car pt1) (car pt2)) 2) (/ (+ (cadr pt1) (cadr pt2)) 2)))
(command "text" "_s" "standard" pt4 "0.25" "90" "Sant")
Edited by Isaac26a
One problem that you have to keep in mind. pt1 has to be left of pt2. updated the wording of Select point so you dont select backwards.
Made a check so things are drawn the same no matter the order of points picked.
if your always going to pick left to right just remove the if statments and the 2nd option for pt3 and pt4
(defun C:SNT (/ pt1 pt2 pt3 pt4 midist distlung)         ; its always good to list our variables
  (defun DtR (d) (* pi (/ d 180.0)))                     ; converts Degrees to Radians
  (setq pt1 (getpoint "\nSelect Point 1:"))
  (setq pt2 (getpoint "\nSelect Point 2:"))
  (if (< (car pt1) (car pt2))
    (setq pt3 (polar pt1 (DtR 330) distlung))              ; uses DtR to convert to radians
    (setq pt3 (polar pt1 (DtR 210) distlung))              ; uses DtR to convert to radians
  (command "_.Pline" pt1 pt3 pt2 "")					           ; make one pline instead of two lines
    (setq pt4 (polar pt1 0 midist))   					           ; easier point caclulation.
    (setq pt4 (polar pt2 0 midist))
  (command "_.Text" "_S" "Standard" "_J" "ML" pt4 "0.25" "90" "Sant")  ;added middle left justify
Edited by mhupp
removed visual lisp commands
Expand
I think Mhupp made a good solution, you just have to change vl-cmdf for command, since it's only plain lisp.
  • Thanks 1
You want 2 drains or more ? See while.
  (while (setq pt1 (getpoint "\nSelect Point 1: press Enter to leave"))
) ; while
Big thanks to Isaac26a mhupp  and BIGAL
Now my workflow improved a lot, and I have the base to create more Lisp for other elements I want to speedup in CAD work.
One more question, If I want to add another command in same Lisp file, for example once I finished the ditches I wan to run a draw road axis function, (something similar, pick center point, left ,right,...) I can add a different function in same Lisp, or should I create another lisp for that ?
Typu can have multiple function in one *.lsp file or separate function in two *.lsp files. Your one lisp function (your SNT for example) can do as much as You want. For example You can do ditches and axis on one lisp function (SNT do ditches and axis). Or in two function one for ditches one for axis (SNT and for example AX). Is just as You want and as You need
Edited by zwonko
Expand
Thanks zwonko, just working on adding a second function and command on same lisp file, and test how it works
found this topic :
Thanks a lot for support
Romeo
Edited by romparkin
You can chain defuns into a sequence
run as one
SNT
AX
(defun c:sntax ()
(C:SNT)
(C:ax)
Hi romparkin.
What software are you using to make the cross section?
  On 10/27/2021 at 7:28 AM, diskoalnis said:
Hi romparkin.
Expand
Hi , I have  a license of Progecad 2021 , an it has an addon called Autosez , see here:
https://www.progesoft.com/products/progecad-professional/manual?mp=progecad-features/add-on-advanced-functions/autosez
As I understand,  the developer of this addon, made it as a lisp originally, but the addon on Progecad was made specially for this Intellicad version.
The original lisp can found on this forum (italian language, but use google to translate it )
https://www.cad3d.it/forum1/threads/autosez-2-sezioni-e-profili-del-terreno-estrazione-automatica.17601/page-10
I hope that helps
Romeo
