To get repeated in a list
devitg
Hi all, this  defun  removes duplicated in a list
(DEFUN REMOVE-DUPS  (LISTE / RETLISTE) ;_ 01
  (FOREACH ITEM  LISTE
    (IF (NOT (MEMBER ITEM RETLISTE))
      (SETQ RETLISTE (CONS ITEM RETLISTE))
  (REVERSE RETLISTE)
(REMOVE-DUPS (list 1  2 2 3 4 4 5  6 6  6 ))
;(1 2 3 4 5 6)
But I need to have the repeated
like
( 2 2 4 4 6 6  6) or at least
( 2 4  6 )
some like
(defun get-repeated ( list  /)
Probably a better way to do this. but this will get what you need.
(DEFUN Dup-count  (lst / i c a Dup-lst lstx x)
  (setq i -1)
  (foreach x lst
    (setq a 0)
    (setq c 0)
    (repeat (length lst)
      (if (equal x (nth a lst))
        (setq c (1+ c))
      (setq a (1+ a))
    (setq i (1+ i))
    (if (not(member (cons x c) Dup-lst))
      (if (> c 1)
        (setq Dup-lst (cons (cons x c) Dup-lst))
  (foreach x Dup-lst
    (repeat (cdr (assoc (car x) dup-lst))
      (setq lstx (cons (car x) lstx))
  lstx
the dup-lst has the items + the number of times its in the list like this.
(2 . 3)
I don't know how to pull the 2nd number from that (cadr x) doesn't seem to work.
figured it out need to use assoc
(dup-count '(1 2 2 2 3 4 5 6 6 6 7 8 9 9 9))
(2 6 9)
(2 2 2 6 6 6 9 9 9)
Edited by mhupp
added repeat
Here is my attempt. :)
(defun Get:Duplicates ( l / f n)
  (mapcar '(lambda (x) (and (setq f (member x l))
                            (member x (cdr f))
                            (or (member x n)
                                (setq n (cons x n))))
          l)
  (reverse n)
like i said better ways to do it! so much cleaner. really need to sit down and learn mapcar and lambda.
Edited by mhupp
Maybe something I found recently and using.
; By Gile
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
Then a VL-sort ?
(setq lst (vl-sort lst '(lambda (x y) (< (car x)(car y)))))
Recursive -
(defun f ( l )
    (if l
        (if (vl-position (car l) (cdr l))
            (cons (car l) (f (vl-remove (car l) (cdr l))))
            (f (cdr l))
Iterative -
(defun g ( l / r x )
    (while (setq x (car l) l (cdr l))
        (if (vl-position x l)
            (setq r (cons x r) l (vl-remove x l))
    (reverse r)
Edited by Lee Mac
