jatin1990 Posted August 16, 2009 Posted August 16, 2009 I was unable to find such a command in 2004. However, there is a convtosurface command in 2009. Will this command will do the job to subtract the solid objects from object created by edgesurf command , by first converting edgesurf object to region? As i have look at number of real physical object which required to creates recess in very irregular shapes. So i am just curise how they do it? Quote
ReMark Posted August 16, 2009 Posted August 16, 2009 The command will do just as it says. No more, no less. Maybe you need to use a different piece of software, other than AutoCAD, or maybe you need to update to 2010 where you'll be given more control over free form objects. Quote
