MJLM Posted October 8, 2021 Posted October 8, 2021 I m trying to get the selection set I just pasted with 'pasteclip' command from an other drawing but with no luck. Is it possible? I though the 'vl-bb-set' & 'vl-bb-ref' would work but they do not seem to be working for sel. sets. Any ideas appreciated. Thanks Quote
mhupp Posted October 8, 2021 Posted October 8, 2021 (edited) (setq SS (ssget "_L")) from Lee Mac's website Selects the last visible object added to the drawing database. Caution: when using the "L" selection method in an MDI environment, you cannot always count on the last object drawn to remain visible. For example, if your application draws a line, and the user subsequently minimizes or cascades the AutoCAD drawing window, the line may no longer be visible. If this occurs, ssget with the "L" option will return nil. Edited October 8, 2021 by mhupp Quote
MJLM Posted October 8, 2021 Author Posted October 8, 2021 Thanks but that only works for one entity. I am talking about a selection set of entities. Quote
mhupp Posted October 8, 2021 Posted October 8, 2021 (edited) 6 minutes ago, MJLM said: Thanks but that only works for one entity. I am talking about a selection set of entities. oops my bad. This is what I use when i explode stuff in a selection set and want to keep it in the same SS. (setq LastEnt (entlast)) *Paste items into drawing (setq SS (ssadd)) (if (setq en (entnext LastEnt)) (while en (ssadd en SS) (setq en (entnext en)) ) ) Edited October 8, 2021 by mhupp Quote
dan20047 Posted October 8, 2021 Posted October 8, 2021 I use reactors to save the last entity to a variable when a command such as paste or copy will start, then collect the new entities created when a command ends. I access those entities with a command that uses the variable for selection, example c:SEPP selects previous created, c:MPP moves previous created. (I use c:MP to move previous selection). (defun c:ML () (command "MOVE" "L" "") (princ)) (defun c:MP () (command "MOVE" "P" "") (princ)) (defun c:MPP () (if (not SAA_Previous) (setq SAA_Previous "P"))(command "MOVE" SAA_Previous "") (princ)) ;; move previous from saved variable (defun c:SEPP () (if (not SAA_Previous) (setq SAA_Previous "P"))(command "SELECT" SAA_Previous "")(sssetfirst SAA_Previous SAA_Previous) (princ)) (defun c:CP () (command "COPY" "P" "") (princ)) (defun c:CPP () (if (not SAA_Previous) (setq SAA_Previous "P"))(command "COPY" SAA_Previous "") (princ)) ;; move previous from saved variable I don't have time to extract just the reactor code for above as an example, but attached is my full reactor file. It won't run by itself as it depends on lots of subroutines from another file, but it contains the full structure of setting up reactors based on Eric Schneider's Autolay and vlr-manager. Search for SAA_Previous_Last for where it is called by the reactors. This code does the same as mhupp above, except deals with last subentities. ;;;============================================================================== ;;; Returns selection set of all entities after passed in entity name ;;; taken from CAD Cookbook utilities ;;;============================================================================== (defun SAA_AFTER (ename / ss) (setq ss (ssadd)) ;create selection set (if ename (while (setq ename (entnext ename)) (ssadd ename ss) ;add entities to set ) ;;; (setq ss (ssget "X")) ;if no last entity, get all ) ;end if (if (> (sslength ss) 0) ss) ;return nil if no entities ) ;;;============================================================================== ;;; Returns last entity, even subentities on polylines ;;; used to ensure SAA_AFTER skips to the next full entity, not just a subentity ;;; ;;; by roy_043 from http://www.theswamp.org/index.php?topic=35626.msg408522#msg408522 ;;;============================================================================== (defun SAA_GetLast ( / ent newEnt) (setq ent (entlast)) (while (and ent (setq newEnt (entnext ent)) ) (setq ent newEnt) ) ent ) saa_reactors.lsp 1 Quote
tombu Posted October 10, 2021 Posted October 10, 2021 Rather than using paste why not use Paste as Block Ctrl+Shift+V? I'd use my Paste as Group macro: ^C^C_pasteblock;\(setq LstBlk(vla-get-Name (vlax-ename->vla-object (entlast))));_explode;_last;_-group;_create;*;;_previous;;(command "-purge" "B" LstBlk "N") (setq LstBlk nil) 1 Quote
