notredave Posted October 7, 2021 Posted October 7, 2021 Good morning all, I'm having a problem printing this and 4 other drawings that are in paperspace. If I click on the model tab, it prints but I want to print from the 24X36 paperspace tab. Is there a setvar or something I'm missing? I am attaching a a drawing that has this problem, there are 4 others that are behaving the same way. Any guidance will be appreciated. I've tried unchecking and checking box (Plot paperspace last) to no avail. I'm using the default main printer that has no problem printing except for these drawings in paperspace. test drawing.dwg Quote
Dana W Posted October 7, 2021 Posted October 7, 2021 In order to print from a paperspace layout, you need to define a page set up apparently. I also got nothing, not even a preview, until I defined a layout with a paper size and a printer of some kind assigned to it. I used the printer/plot device = dwg to pdf.pc3, and printed it on 24X36 portrait to a pdf doc. Try it. Go to the output tab, click page set up manager and tell it the details it needs. Quote
