B.N. Posted October 5, 2021 Share Posted October 5, 2021 Hi, I'm modeling for excavations on GPS. The software on the excavators is Trimble Earthworks. I can use file flipper to convert a LandXML file (even a dxf) to a usable format for the machines. My problem: I can export to dxf and only get lines... tin surfaces can't be extracted from a dxf..... I can export to LandXML, but i don't know how to export the lines. The export only seems to use the tin surface.... Anyone has a method? Thanks!!! w0677 0610.dwg w0677 0610-2.dxf Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 6, 2021 Share Posted October 6, 2021 (edited) From the dwg it looks like a CIV3D surface, contact who you got it off and ask for 3dfaces and a surface, then use faces. Edited January 20, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
B.N. Posted January 20, 2022 Author Share Posted January 20, 2022 On 10/6/2021 at 4:56 AM, BIGAL said: Are you using CIV3D ? We just made 3dfaces from the design surface TIN, that can be read into the 3d Machine control. Ex Topcon employee. The problem is, to import into Trimble, i have to choose either the surface or the linework. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 20, 2022 Share Posted January 20, 2022 (edited) Edited wrong post From the dwg it looks like a CIV3D surface, contact who you got it off and ask for 3dfaces and a surface, then use faces. Edited January 20, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 21, 2022 Share Posted January 21, 2022 CadTools should have what you need. Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted May 9, 2022 Share Posted May 9, 2022 (edited) You can use Trimble Business Center (TBC) to import the XML file from civil3D (use the 'Export to LandXML' function to get a correct XML file from a single surface object), use the DXF files for the 'line view'. in TBC you can export to the right files. Open TBC, create a new file (will show a dark blank area), just drag and drop the .XML and .DXF in the empty space and it will do the rest. At the 'home' tab there is an 'Export' function and you kinda have to figure out what you need there. My language is other than english, so it might be the 'Construction' tab and a 'Machine job site design export'. The rest probably is self explanatory. Depending on the age of the machine you need 2 files or a sort of ZIP file that contains the needed files (mostly the newer machines). U usually need these 2 filestypes: Linework.SVL Design3D.SVD The free version of TBC can do these exports. So no need for a payed version. Edited May 9, 2022 by OMEGA-ThundeR Quote Link to comment Share on other sites More sharing options...
