paulmcz Posted September 27, 2021 Posted September 27, 2021 Is there a way to close "Alert" dialog box, without user input, in about 5 seconds after it appears on screen? Thanks. Quote
dan20047 Posted September 27, 2021 Posted September 27, 2021 Doslib provides an option, see dos_msgbox routine. https://wiki.mcneel.com/doslib/home For info w/out downloading: https://www.afralisp.net/archive/lispa/lisp59.htm 1 Quote
mhupp Posted September 27, 2021 Posted September 27, 2021 (edited) with doslib (dos_msgbox "text" "title" button icon [duration]) (dos_msgbox "This Alert will disappear on hitting ok or after 10 seconds" "Alert" 1 3 10) duration The duration time in seconds. Note, duration only works with button bit values 1, 2, 3 and 5 https://wiki.mcneel.com/doslib/home Edited September 27, 2021 by mhupp dan20047 is to quick!!! 1 Quote
paulmcz Posted September 27, 2021 Author Posted September 27, 2021 Gentlemen, thank you very much. Quote
BIGAL Posted September 28, 2021 Posted September 28, 2021 If the alert is a std statement then you can display a slide with a message including time delay , but there is no OK button you have to set how long it should display. I have this on 1st load of some lisps. Quote
Crank Posted October 3, 2021 Posted October 3, 2021 (edited) (defun MsgBox (title buttons message time / return WshShell) ; ; Val buttons (boolean) ; 0=OKOnly 1=OKCancel 2=AbortRetryIgnore 3=YesNoCancel 4=YesNo 5=RetryCancel 6=CancelRetryContinue ; 16=Katakana 32=Question 48=Exclamation 64=Information ; 0 First button is default. ; 256 Second button is default. ; 512 Third button is default. ; 768 Fourth button is default. ; 0 Application modal; the user must respond to the message box before continuing work in the current application. ; 4096 System modal; all applications are suspended until the user responds to the message box. ; ; Val return ; 1=OK 2=Cancel 3=Abort 4=Retry 5=Ignor 6=Yes 7=No ; ; Time has to be a number (integer or real), if it's greater than 0, the box automaticaly closes after about ; 1+ time seconds. If it's set to 0 the box won't close until the user closes it by clicking a button. (setq WshShell (vlax-create-object "WScript.Shell")) (setq return (vlax-invoke WshShell 'Popup message time title (itoa buttons) )) (vlax-release-object WshShell) return ) Edited October 3, 2021 by Crank Quote
BIGAL Posted October 4, 2021 Posted October 4, 2021 If it's greater than 0, the box automatically closes after about 1+ time seconds. Not working or am I doing some thing wrong ? Quote
kirby Posted October 4, 2021 Posted October 4, 2021 Timeout function doesn't seem to be working, this has been a Windows problem for 10+ years e.g. the following never times out (setq Ans (msgbox "My Message" 64 "This is a message\nspanning two lines" 5)) Quote
paulmcz Posted October 4, 2021 Author Posted October 4, 2021 Thanks for the code Crank but it makes unpredictable time delays. Maybe a Windows (7) problem as Kirby says? (msgbox "testing time delay" 4096 "testing 10 secs" 10) This has produced a time delays between 20 and 45 seconds randomly in 5 consecutive tries Quote
Crank Posted October 4, 2021 Posted October 4, 2021 (edited) Yes the timer is unreliable What you can do: (defun MsgBox (title options message time / WshShell) (setq WshShell (vlax-create-object "WScript.Shell")) (vlax-invoke WshShell 'Run (strcat "mshta.exe vbscript:close(CreateObject(\"WScript.Shell\").Popup(\"" message "\"," (itoa time) ",\"" title "\"," (itoa options)"))" ) ) (vlax-release-object WshShell) ) That always returns 0, so cannot detect which button was pressed. But this shouldn't have to be a problem when you only have one button. Edited October 5, 2021 by Crank 1 Quote
paulmcz Posted October 4, 2021 Author Posted October 4, 2021 Yes, this works like magic and it is very close to the time I set. Thank you very much Crank. Quote
Crank Posted October 5, 2021 Posted October 5, 2021 You're welcome. In case you didn't notice, I've made a small correction. Quote
paulmcz Posted October 5, 2021 Author Posted October 5, 2021 (edited) I used your code from your last post and it worked well. What is your today's correction improving? Edited October 5, 2021 by paulmcz Quote
BIGAL Posted October 5, 2021 Posted October 5, 2021 I can see this being a nice "You have x more goes in this trial" with say 1 second. Quote
Paul Li Posted March 24, 2022 Posted March 24, 2022 (edited) very nice message box with time dismissal. any way to force the message window to occur on the same screen as AutoCAD since I have multiple screens? I know there's this function that can do it but how to implement? (vla-get-HWND (vlax-get-Acad-Object)) (vlax-invoke WshShell 'Run Edited March 24, 2022 by Paul Li grammar Quote
marko_ribar Posted April 2, 2022 Posted April 2, 2022 (edited) I don't know if this is still relevant, but in my BricsCAD - neither one disappears when time elapsed... So it took me a while until I've cobbled this one which will do the trick, but it's somewhat convolutet, uses 3 separate tmp files and plus it brings up black blank cmd screen upon starting tmp *.bat file... But if that could be resolved in the future - this could be the correct way to overcome this issue - "time" argument version... (defun MsgBox ( title buttons message time / filename1 filename2 fn li catch ret ) ;;; VBScript method ;;; ;Val buttons (boolean) ;0=OKOnly 1=OKCancel 2=AbortRetryIgnore 3=YesNoCancel 4=YesNo 5=RetryCancel 6=CancelRetryContinue ;16=Katakana 32=Question 48=Exclamation 64=Information ;0 First button is default. ;256 Second button is default. ;512 Third button is default. ;768 Fourth button is default. ;0 Application modal; the user must respond to the message box before continuing work in the current application. ;4096 System modal; all applications are suspended until the user responds to the message box. ; ;Val return ;1=OK 2=Cancel 3=Abort 4=Retry 5=Ignor 6=Yes 7=No nil=TIME elapsed ; ;Time has to be a number (integer or real), if it's greater than 0, the box automaticaly closes after about ;time seconds. If it's set to 0 the box won't close until the user closes it by clicking a button. (setq filename1 (vl-filename-mktemp "XXXX.vbs" (getvar 'tempprefix))) (setq fn (open filename1 "w")) (write-line (strcat "strText=\"" message "\"") fn) (write-line (strcat "strTitle=\"" title "\"") fn) (write-line (strcat "intType=" (itoa buttons)) fn) (write-line (strcat "Set objWshShell=WScript.CreateObject(\"WScript.Shell\"")) fn) (write-line (strcat "ret=objWshShell.Popup(strText, " (if (zerop time) "" (cond ( (= (type time) 'int) (itoa time) ) ( (= (type time) 'real) (rtos time) ))) ", strTitle, intType)") fn) (write-line "WScript.Echo ret" fn) (close fn) (setq filename2 (vl-filename-mktemp "XXXX.bat" (getvar 'tmpprefix))) (setq fn (open filename2 "w")) (write-line (strcat "for /f \"tokens=*\" %%i in ('cscript //nologo " filename1 "') do set RETURN=%%i") fn) (write-line (strcat "echo %RETURN% > " (getvar 'tempprefix) "txt.txt") fn) (close fn) (startapp filename2) (while (not (findfile (strcat (getvar 'tempprefix) "txt.txt")))) (setq fn (open (strcat (getvar 'tempprefix) "txt.txt") "r")) (if (= (type (setq li (read-line fn))) 'str) (setq catch (vl-catch-all-error-p (setq ret (vl-catch-all-apply (function atoi) (list li))))) ) (close fn) (if (findfile filename1) (vl-file-delete filename1) ) (if (findfile filename2) (vl-file-delete filename2) ) (if (findfile (strcat (getvar 'tempprefix) "txt.txt")) (vl-file-delete (strcat (getvar 'tempprefix) "txt.txt")) ) (if (not catch) (if (/= ret -1) ret ) ) ) HTH. Regards, M.R. Edited April 4, 2022 by marko_ribar Quote
BIGAL Posted April 3, 2022 Posted April 3, 2022 My Bricscad V20 works fine about 1 second (defun MsgBox (title options message time / WshShell) (setq WshShell (vlax-create-object "WScript.Shell")) (vlax-invoke WshShell 'Run (strcat "mshta.exe vbscript:close(CreateObject(\"WScript.Shell\").Popup(\"" message "\"," (itoa time) ",\"" title "\"," (itoa options)"))" ) ) (vlax-release-object WshShell) ) (msgbox "Pts on wall" 0 "Select COGO points" 1) Quote
marko_ribar Posted April 3, 2022 Posted April 3, 2022 Here is the one stolen from "vle-extension.lsp" founded in root of BricsCAD... I am posting it as it has good info comment - very exhaustive and well explained... ;;================================================================================ ;;| FUNCTION : vle-alert | ;;|------------------------------------------------------------------------------| ;;| Author: Lee Mac, Copyright © 2012 - www.lee-mac.com | ;;|------------------------------------------------------------------------------| ;;| Original code: http://lee-mac.com/popup.html | ;;|------------------------------------------------------------------------------| ;;| (vle-alert title msg flags) | ;;| | ;;| shows a message box, which can be customised in wide range (based on Windows | ;;| ::MessageBox() function) | ;;| | ;;| Arguments : 'title' title for the message box (the caption string) | ;;| : 'msg' the message to be displayed; will be word-wrapped | ;;| : 'flags' combination (addition) of integers specifying behaviour | ;;| | ;;| : flags for button : | ;;| MB_OK 0 | ;;| MB_OKCANCEL 1 | ;;| MB_ABORTRETRYIGNORE 2 | ;;| MB_YESNOCANCEL 3 | ;;| MB_YESNO 4 | ;;| MB_RETRYCANCEL 5 | ;;| MB_CANCELTRYCONTINUE 6 | ;;| MB_HELP 16384 | ;;| | ;;| : flags for icons : | ;;| MB_ICONHAND / MB_ICONSTOP 16 | ;;| MB_ICONQUESTION 32 | ;;| MB_ICONEXCLAMATION 48 | ;;| MB_ICONASTERISK /MB_ICONINFORMATION 64 | ;;| | ;;| : flags for default button (for <return> input) : | ;;| MB_DEFBUTTON1 0 | ;;| MB_DEFBUTTON2 256 | ;;| MB_DEFBUTTON3 512 | ;;| MB_DEFBUTTON4 768 | ;;| | ;;| : flags for behaviour : | ;;| MB_APPLMODAL 0 | ;;| MB_SYSTEMMODAL 4096 | ;;| MB_TASKMODAL 8192 | ;;| | ;;| MB_SETFOREGROUND 65536 | ;;| MB_DEFAULT_DESKTOP_ONLY 131072 | ;;| | ;;| MB_TOPMOST 262144 | ;;| MB_RIGHT 524288 | ;;| MB_RTLREADING 1048576 | ;;| | ;;| Return : number of button which was used to finish the dialogue | ;;| 1 OK button | ;;| 2 Cancel button | ;;| 3 Abort button | ;;| 4 Retry button | ;;| 5 Ignore button | ;;| 6 Yes button | ;;| 7 No button | ;;| 10 Try Again button | ;;| 11 Continue button | ;;| | ;;| Example : (vle-alert "My CAD App" "Dear Customer ...." (+ 4 32 4096)) | ;;| will show Yes+No button, the question mark icon, as system modal dialogue | ;;================================================================================ (if (not vle-alert) (defun vle-alert ( title msg flags / wsh res ) (vl-catch-all-apply (function (lambda () (setq wsh (vlax-create-object "wscript.shell")) (setq res (vlax-invoke-method wsh 'popup msg 0 title flags)) ) ) ) (if wsh (vlax-release-object wsh)) res ) ) Quote
marko_ribar Posted April 4, 2022 Posted April 4, 2022 (edited) Here is my latest one, but still the same or a little bit different issue - black background of cmd shell window - (startapp) function : it can't be avoided!!! Also - it is VBScript method that is used in global... [ EDIT : I think I've managed to avoid black cmd screen by using (dos_shellexe) function - you must have DosLib installed.../ EDIT ] (defun MsgBox ( title buttons message time / filename fn li catch ret ) ;;; VBScript method ;;; ;Val buttons (boolean) ;0=OKOnly 1=OKCancel 2=AbortRetryIgnore 3=YesNoCancel 4=YesNo 5=RetryCancel 6=CancelRetryContinue ;16=Katakana 32=Question 48=Exclamation 64=Information ;0 First button is default. ;256 Second button is default. ;512 Third button is default. ;768 Fourth button is default. ;0 Application modal; the user must respond to the message box before continuing work in the current application. ;4096 System modal; all applications are suspended until the user responds to the message box. ; ;Val return ;1=OK 2=Cancel 3=Abort 4=Retry 5=Ignor 6=Yes 7=No nil=TIME elapsed ; ;Time has to be a number (integer or real), if it's greater than 0, the box automaticaly closes after about ;time seconds. If it's set to 0 the box won't close until the user closes it by clicking a button. (setq filename (vl-filename-mktemp "XXXX.vbs" (getvar 'tempprefix))) (setq fn (open filename "w")) (write-line "Dim strText, strTitle, intType, fso, f, ret" fn) (write-line (strcat "strText = \"" message "\"") fn) (write-line (strcat "strTitle = \"" title "\"") fn) (write-line (strcat "intType = " (itoa buttons)) fn) (write-line (strcat "ret = WScript.CreateObject(\"WScript.Shell\").Popup(strText, " (if (zerop time) "" (cond ( (= (type time) 'int) (itoa time) ) ( (= (type time) 'real) (rtos time) ))) ", strTitle, intType)") fn) (write-line "Set fso = WScript.CreateObject(\"Scripting.FileSystemObject\")" fn) (write-line (strcat "Set f = fso.CreateTextFile(\"" (getvar 'tempprefix) "txt.txt\", True)") fn) (write-line "f.Write ret" fn) (write-line "f.Close" fn) (write-line "Set strText = Nothing" fn) (write-line "Set strTitle = Nothing" fn) (write-line "Set intType = Nothing" fn) (write-line "Set fso = Nothing" fn) (write-line "Set f = Nothing" fn) (write-line "Set ret = Nothing" fn) (close fn) (if (vl-some (function (lambda ( x ) (vl-string-search "doslib" x))) (arx)) (dos_shellexe "c:\\windows\\system32\\cscript.exe" (strcat "\"" filename "\" //nologo") 0 3) (startapp (strcat "c:\\windows\\system32\\cscript.exe \"" filename "\" //nologo")) ) (while (not (findfile (strcat (getvar 'tempprefix) "txt.txt")))) (setq fn (open (strcat (getvar 'tempprefix) "txt.txt") "r")) (if (= (type (setq li (read-line fn))) 'str) (setq catch (vl-catch-all-error-p (setq ret (vl-catch-all-apply (function atoi) (list li))))) ) (close fn) (if (findfile filename) (vl-file-delete filename) ) (if (findfile (strcat (getvar 'tempprefix) "txt.txt")) (vl-file-delete (strcat (getvar 'tempprefix) "txt.txt")) ) (if (not catch) (if (/= ret -1) ret ) ) ) Edited April 6, 2022 by marko_ribar Quote
marko_ribar Posted April 6, 2022 Posted April 6, 2022 Managed to implement msgbox like it should - only you have to have installed DosLib... Bye... Quote
