What about data storage from the entget?
I have a code like that,
(defun c:example1 (/ )
  (setq a (entsel "Select an entity "))
 (setq b (entget a))
Αt the end of the code by calling the variable "a" I see its contents normally (entity name and coordinates) and I also see that the list normally comes out of the command from entget. However when I call the variable "b", my command prints the message "extra cdrs in dotted pair on input" what am i doing wrong?
 (setq b (entget a))
You have the grab the ename from entsel using CAR like so:
(setq b (entget (car a)))
And if you want to print the items to the command line use something like so:
(if (setq a (entsel))
  (mapcar 'print (entget (car a) '("*")))
Edited by ronjonp
If using VL code
;;; DumpIt                                                            ;
;;; Dump all methods and properties for selected objects              ;
(defun C:Dumpit ( / ent)
  (while (setq ent (entsel))
    (vlax-Dump-Object
      (vlax-Ename->Vla-Object (car ent))
