Select Objects By Crossing Window
Good Morning.  Just wondering if there is a quick and easy method to change lisps that select objects individually, so that you can select multiple objects with a crossing window.  Perhaps just one line of ominous code that can be thrown in at a designated spot?  I have a few different lisps that I'm wanting to make this change to.  Tks.
Awesome.  Thanks for all of the help.
I've been doing my best to insert this into the existing code with a fair amount of research on my end, but i'm continuing to come up short.  Any chance I could get some direction.  I understand the general concept and difference between SSGET and NENTSEL, i'm just having a hard time executing it.
TEST.lsp
That code does use nentsel , but it's enclosed within a user-defined function "LM:SelectIf" to make it easier to select an object. Unfortunately that function will only allow for a single object selection. In order to make it to multiple selection, you would have to completely modify the LM:SelectIf function and then some more minor adjustment on the actual MATCHPIPE command to account for that function change. I could easily modify it for you, but it's not really my style to modify people's work.
Edited by Jonathan Handojo
Like Ronjonp you can add ssget filters (setq ss (ssget "_C" pt1 pt2 '((0 . "INSERT")))) will only get blocks so could add name and layer etc.
Thank you both for your help.  I think I can work with this information.
