Hi friends I need lisp code for display alert massage one first time use of function. When user use that command then that alert massage don't shown on screen
Edited by Halsy
Assuming you're talking about one of your lisp functions have it save a value to a global variable but check that value first and if it's nil display the alert message.
2 minutes ago, Halsy said:
Can you provide code for same
Can you provide the code for the function you want modified?
(defun c:scpanel (/ p1 p2 p3 p4 p5 p6 p7 left right oldsnap)
(alert " Please use Maximum number of 400 SC 400")
(setq p1 (getpoint "\ pick a corner point: "))
(setq oldsnap (getvar ' osmode))
(setvar ' osmode 0)
(setq left (getreal "\ Enter Leftside of panel: ")
         right (getreal "\ Enter Rightside of panel: ")
(setq p2 (polar p1 (* pi 1.5) left)
          p3 (polar p2 0 100)
          p4 (polar p3 ( / pi 2) (- left 100))
          p5 (polar p1 0 right)
          p6 (polar p4 0 (- right 100))
(command "pline" p1 p2 p3 p4 p6 p5 p1 "c")(setq s(entlast))
(command ".text" p4 65 0 (strcat  (rtos left 2 0 ) " SC " (rtos right 2 0 ) ))(setq s1(entlast))
(setvar ' osmode oldsnap)
(repeat 2
(setq ang (getangle "\nEnter Rotation angle: "))
(setq ang1 (* 180.0 (/ ang pi)))
(command "rotate" s s1 "" p1 ang1 "")
this massage has to display only once when user use scpanel command
Try
(if ±×alert×±
  (setq ±×alert×± 1)
(setvar ' osmode 0)
          p3 (polar p2 0 100)
(repeat 2
when i use scpanel command then alert is not come on the screen but 2 time of use it come on the screen
i need only one time when command runs for 1st time
Try swapping:
(if ±×alert×±
  (setq ±×alert×± 1)
to
(if (= myalert nil)
    (setq myalert 1)
Edited by Steven P
A correction
adding to this, the alert will show first time you use the command each session for each drawing, you might also look at saving the values of myalert into a registery key similar to this
(if (eq (vl-registry-read "HKEY_CURRENT_USER\\Software\\TOMMY\\TIMMY") "1")(ALERT "THE KEY EXISTS AND IS SET TO 1") (Alert "THE KEY DOES NOT EXIST"))
which will show the alert only once until you reset the registry key
( https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-registry-key-value-and-process-it/td-p/3733306 )
@Halsy
Try something like this:
(or (getenv "NameYouWantToUse") (progn (alert "Hello World!") (setenv "NameYouWantToUse" "Ran")))
And how to store floor height bye selecting floor bottom and floor top
If you want to display the message for the first time of that certain lisp call and for each ACAD session, then apparently you'll have to use a reactor:
  ; (alert " Please use Maximum number of 400 SC 400")
  (setvar ' osmode 0)
    p3 (polar p2 0 100)
  (repeat 2
  (lambda ( rnm cmd msg )
    ; Alert once code snippet by Grrr
    (setq cmd (strcase cmd))
    (foreach rtr (cdar (vlr-reactors :vlr-lisp-reactor)) (if (= cmd (vlr-data rtr)) (vlr-remove rtr)) )
    (eval (list (quote VLR-Lisp-Reactor) (quote cmd) (list (quote quote) (list (cons :VLR-lispWillStart rnm)))))
    (eval
      (list 'defun rnm (list 'rtr 'arg '/ 'rtn)
        (list	'cond
          (list
            (list '= cmd (list 'car 'arg))
            (list 'alert msg)
            (list 'vlr-remove 'rtr)
            (list 'setq rnm nil)
        (list 'princ)
    ); eval
  ); lambda
  'SCpanel:AlertOnce:CB ; Reactor's callback function name
  "(C:SCPANEL)" ; The lisp command call to trace
  " Please use Maximum number of 400 SC 400" ; The alert message
See the lambda code snippet below of your code and adjust the arguments for your needs. ;)
Edited by Grrr
@Halsy
Food for thought:
(defun c:scpanel (/ ang ang1 left oldsnap p1 p2 p3 p4 p5 p6 right s s1)
  ;; Run once daily
;;;  (or (= (rtos (getvar 'cdate) 2 0) (getenv "NameYouWantToUse"))
;;;      (progn (alert "Hello World!") (setenv "NameYouWantToUse" (rtos (getvar 'cdate) 2 0)))
  ;; Check your input rather than alerting once daily your rules
  (cond	((and (setq p1 (getpoint "\nPick a corner point: "))
	      (< (setq left (getreal "\nEnter Leftside of panel: ")) 400)
	      (< (setq right (getreal "\nEnter Rightside of panel: ")) 400)
	 (setq oldsnap (getvar 'osmode))
	 (setvar 'osmode 0)
	       p3 (polar p2 0 100)
	       p4 (polar p3 (/ pi 2) (- left 100))
	 (setq s (entlast))
	 (command ".text" p4 65 0 (strcat (rtos left 2 0) " SC " (rtos right 2 0)))
	 (setq s1 (entlast))
	 (setvar 'osmode oldsnap)
	 (repeat 2
	((alert "Please use Maximum number of 400"))
Edited by ronjonp
