Hi all, how do I build an if-function where at least one of two conditions must be met?
So if one of these .txt files or both are found. Thanks in advance.
(if
  (or
    (findfile (strcat "\\path\\" "one.txt")
              (strcat "\\path\\" "two.txt")
You were close, just needed to use findfile for each path:
(if
  (or
    (findfile (strcat "\\path\\" "one.txt"))
    (findfile  (strcat "\\path\\" "two.txt"))
  ; one of the files was found .. do stuff
Or if you need to determine if both files were found, you can use cond :
(setq file1 (findfile (strcat "\\path\\" "one.txt")))
(setq file2 (findfile (strcat "\\path\\" "two.txt")))
(cond
  ( (and file1 file2)
    (princ "found both files")
    ; do stuff...
  ( file1
    (princ "found file1")
    ; do stuff...
  ( file2
    (princ "found file2")
    ; do stuff...
  (t
    (princ "no files were found")
    ; do stuff...
); cond
  • Agree 1
Thanks for the quick reply! The bad boy works now.
100% @Grrr if you want more detail you could also do.
(cond
  ((and file1 file2)
    (princ "\nFound both files:")
    (princ (strcat "\n" file1))
    (princ (strcat "\n" file2))
    ; do stuff...
  (file1
    (princ (strcat "\nFound: " file1))
    ; do stuff...
  (file2
    (princ (strcat "\nFound: " file2))
    ; do stuff...
  (t
    (princ "\nNo files were found")
    ; do stuff...
)  ; cond
"found both files"
"C:\project1\text\one.txt"
"C:\project1\text\two.txt"
or
"Found: C:\project1\text\one.txt"
instead of
"found  both files"
or
"found file1"
