Hi all, I have written a lisp that uses the vl-file-copy command to move this PDF to another folder.
But this only works for the original pdf, not for the link!
Does anyone know if I need to change something in the command to be able to move the link?
The file name remains the same: "sheet_cover_building1".
What is your line in your code for the vl-file-copy?
(obviously if it is a shortcut link, the file extension will be .lnk )
  • Like 2
  • Agree 1
With .lnk and .pdf it does'nt work either ..
  	(vl-file-copy (strcat "\\path1\\" Data ".lnk")
                  (strcat "\\path2\\" Data ".pdf")
@mhupp I only store shortcuts in this folder. The original pdf just stored for demonstration.
Edited by Manuel_Kunde
Okay i got it. You have to append this file extension to the source file.
  	(vl-file-copy (strcat "\\path1\\" Data ".pdf - Verknüpfung.lnk")
Does anyone know if it is possible to make a PDF (without shortcut) from the source file that I move to another folder with vl-file-copy?
If I enter the file extension in the destination folder to ".pdf", the file is moved, but Adobe tells me when I open it that the PDF is corrupted.
In this case it would have to convert the .lnk file to .pdf.
Expand
if you have the shortcut link then you -should- be able to get the relevant file path from that. I haven't tried it but this suggests you can do that in VBA ( https://social.msdn.microsoft.com/Forums/en-US/fd6a0d4c-94ea-43b0-87d7-a706eeb04734/how-to-retrieve-the-target-of-a-shortcut-file-in-vb-code ). I don't use VBA so I have no idea if it works or not.. so assuming you can, you should be able to put that in the vl-file-copy and go from there?
