MR MAN Posted February 11, 2009 Share Posted February 11, 2009 Can Any One Help Me In This Lisp I Need Lisp Make That: Qleader-----setting Annaotation Type (block Reference) Annaotation Reuse (none) Leader Line (straight) Arrowhead (closed Fill) Number Of Points (no Limit) Angle Constraints First Segment (60) Second Segment (60) Quote Link to comment Share on other sites More sharing options...
VovKa Posted February 11, 2009 Share Posted February 11, 2009 (defun test (/) (dictremove (namedobjdict) "ACADDIM") (entmod (append (entget (namedobjdict)) (list (cons 3 "ACADDIM") (cons 350 (entmakex '((0 . "XRECORD") (100 . "AcDbXrecord") (280 . 1) (90 . 990106) (3 . "") (60 . 3) (61 . 0) (62 . 1) (63 . 3) (64 . 0) (65 . 0) (66 . 1) (67 . 3) (68 . 1) (69 . 0) (70 . 3) ;45 (71 . 3) ;45 (72 . 0) (40 . 0.0) (170 . 0) ) ) ) ) ) ) ) sorry about 'Angle Constraints', it seems that only predefined values are possible (acad2005) Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 12, 2009 Share Posted February 12, 2009 search for qlsettings.lsp that should give you everything you need. Quote Link to comment Share on other sites More sharing options...
badien Posted February 13, 2009 Share Posted February 13, 2009 You can change system variables with DIM-prefix: DIMADEC DIMALT DIMALTD DIMALTF DIMALTRND DIMALTTD DIMALTTZ DIMALTU DIMALTZ DIMAPOST DIMASO DIMASSOC DIMASZ DIMATFIT DIMAUNIT DIMAZIN DIMBLK DIMBLK1 DIMBLK2 DIMCEN DIMCLRD DIMCLRE DIMCLRT DIMDEC DIMDLE DIMDLI DIMDSEP DIMEXE DIMEXO DIMFIT DIMFRAC DIMGAP DIMJUST DIMLDRBLK DIMLFAC DIMLIM DIMLUNIT DIMLWD DIMLWE DIMPOST DIMRND DIMSAH DIMSCALE DIMSD1 DIMSD2 DIMSE1 DIMSE2 DIMSHO DIMSOXD DIMSTYLE DIMTAD DIMTDEC DIMTFAC DIMTIH DIMTIX DIMTM DIMTMOVE DIMTOFL DIMTOH DIMTOL DIMTOLJ DIMTP DIMTSZ DIMTVP DIMTXSTY DIMTXT DIMTZIN DIMUNIT DIMUPT DIMZIN here is example: (defun c:scaleleader () (setq scale (getreal "Input current scale : ")) (setvar "osmode" 0) ; osnap off (setvar "DIMCLRE" ;Color (setvar "DIMCLRD" ;Color (setvar "DIMCLRT" ;Color (setvar "DIMZIN" 0) ;Trailing (command "STYLE" "2D" "vnsimple" "0" "0.9" "0" "N" "N" "N") (setvar "DIMEXE" (* 0.75 scale)) ;Extension above line (setvar "DIMEXO" (* 0.5 scale)) ;Feature offset (setvar "DIMASZ" (* 1 scale)) ;Arrow size (setvar "DIMBLK" ".") (setvar "DIMBLK2" ".") (setvar "DIMLDRBLK" ".") (setvar "DIMTSZ" 0) ;= 0 Draws arrowheads ;(setvar "DIMTSZ" (* 0.75 scale)) ;= 0 Draws arrowheads ; >0 Draws oblique strokes instead of arrowheads ;(setvar "DIMTSZ" (* 0.5 scale)) ;Tick size 0.7 (setvar "DIMTXT" (* 2.0 scale)) ;Text height 2.5 (setvar "DIMTAD" 1) ;Verical (defauft) (setvar "DIMTIH" 0) ;Horizontal (setvar "DIMTOH" 0) ;Horizontal (setvar "DIMTIX" 1) ;Force text inside (setvar "DIMSOXD" 0) ;Force text inside (setvar "DIMDEC" 2) ; (setvar "DIMSCALE" 0) ; (setvar "DIMGAP" (* 1 scale)) ; ;(setvar "DIMTXSTY" "2D") (setvar "DIMLFAC" 1) (setvar "DIMFIT" 5) ;No Leader (setvar "DIMSE1" 0) ;Suppress (setvar "REGENMODE" 1) (setvar "DIMAUNIT" 1) ;Degrees/minutes/seconds ) Quote Link to comment Share on other sites More sharing options...
