Casio47 Posted September 7, 2021 Share Posted September 7, 2021 Hello I have multiple Lines (not polyline). As I measure (not dimension) each line, how can I keep a running total of each line measured? Instead of adding up each measurement individually and adding them? Thanks for the help 2017 AutoCAD Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 7, 2021 Share Posted September 7, 2021 Use quickcalc. At the top is an icon to let you pick the end points of a line to get it's length, then press + and keep picking out lines. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 7, 2021 Share Posted September 7, 2021 2 hours ago, Casio47 said: Hello I have multiple Lines (not polyline). As I measure (not dimension) each line, how can I keep a running total of each line measured? Instead of adding up each measurement individually and adding them? Thanks for the help 2017 AutoCAD So you only care about the grand total ? Command: MeasureGeom 1 Quote Link to comment Share on other sites More sharing options...
Casio47 Posted September 7, 2021 Author Share Posted September 7, 2021 MeasureGeom worked...thanks 1 Quote Link to comment Share on other sites More sharing options...
