SIMPLYCRAZY Posted September 1, 2021 Share Posted September 1, 2021 (edited) I have a 5 sided lwpolyline that I would like to extract the 3rd point xy & z coordinates to use with dtr function. I have a list with the 5 sets of coordinates, Im not even sure if the list really is correct. Manly will be using with the world coordinates system but may want the z value later. Im thinking I filter the list but unsure how? Any help would be much appreciated. (((130.87 75.334) (131.087 76.5975) (161.817 71.3145) (149.922 27.7314) (148.685 28.0689))) (COMMAND "OFFSET" "L" "C" ROS VR99 VR4 "") (SETQ VR98 (ENTLAST)) (COMMAND "ERASE" VR99 "") (COMMAND "PEDIT" VR98 "JOIN" VR96 VR97 VR98 "" "") (defun massoc ( key lst / rtn ) (foreach x lst (if (= key (car x)) (setq rtn (cons (cdr x) rtn)) ) ) (reverse rtn) ) (IF (AND (setq dxf (entget VR98)) (= "LWPOLYLINE" (cdr (assoc 0 dxf))) ) (SETQ 3RD (LIST (massoc 10 dxf))) ) Edited September 1, 2021 by SIMPLYCRAZY Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 2, 2021 Share Posted September 2, 2021 Your request is confusing, but the answer may be in the fact that whilst an object maybe a "LWPOLYLINE" or "PLOYLINE" it has a secondary property. (setq ss3dpl (ssget "X" (list (cons 0 "POLYLINE") ) You can then look at (cdr (assoc 100 "AcDb3dPolyline")) or (cdr (assoc 100 "AcDbPolyline")) Using say vl get coordinates can work out has XY or XYZ list of points. Need a dwg to work out what you want. Quote Link to comment Share on other sites More sharing options...
Jonathan Handojo Posted September 2, 2021 Share Posted September 2, 2021 LWPOLYLINE is a flat polyline, so you won't have a third coordinate for it and will only have a 2d point. What you're after is the elevation of the polyline that can be extracted from DXF code 38 from entget. Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 2, 2021 Share Posted September 2, 2021 Is this a simple as adding: (nth 2 (nth 0 3rd)) at the end of the LISP? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 3, 2021 Share Posted September 3, 2021 Steven P no (10 188.0 62.0) for a plain pline. (38 . 12.0) which is elevation. A quicky for you in my autoload.lsp, I use these all the time for a quick look at object (defun c:ent ()(entget (car (entsel "Pick")))) or use Dumpit.lsp (100 . "AcDb3dPolyline") (10 0.0 0.0 0.0) get the vertex points. Use VL get coordinates. z= 233 etc Coordinates = (299493.688604032 1222965.59330423 233.721 299493.846604032 1222983.26930423 233.556 299493.916604032 1222989.04330423 233.542 299494.158604032 1222999.75930423 233.394 299494.923604032 1223015.36330423 233.192 299494.923425952 1223016.30612341 233.192 299494.868604032 1223016.74930423 233.191 299494.312604032 1223019.20230423 233.166 299494.396604032 1223024.37930423 233.085 299494.400604032 1223024.88130423 233.055 299495.208062272 1223037.39590885 232.937) 1 Quote Link to comment Share on other sites More sharing options...
